I was reading my instructions manual for the stealth fx bov I bought and it has this written on the bottom.
"GFB products are engineered for best performance, however incorrect use or modification of factory systems may cause damage to or reduce the longevity of the engine/drivetrain components. "
Does this mean that a bov if running correctly without the typical symptoms stalling etc can be harmful to my or your cars engine?? just something that popped into my mind. All these people with bov's when it may be bad for the engine.
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/
the bov or commonly known as recirculation valve was fitted to later model turbocharger cars (earlier models didnt have them, aka vl turbo style) to prevent excessive turbocharger failure and premature wear caused by compressor surge on gearchange.
normally without a blow off valve or recirc value when you back off on the throttle or during gear change the throttle body closes and the pressure has to go somewhere that is built up. it goes back towards to the turbocharger as it has no where else to go and basically gets chopped by the spinning compressor wheel and the blades recieve a fair impact "shunt" by the exessive pressure collision. this can lead to premature turbocharger failre in the bearings and compressor wheel.
another side issue is excessive stalling by an atmosphereic blow off valve, the bov functions as a half recircluation valve, it prevents turbocharger failure by prevent the surge but dumps the pressure to the atmosphere. the engine management system (particulary airflow meter) does not know that the bov is venting to the atmosphere and there expects a certain amount of air present in the system (as its told by airflow meter). however the atmo bov dumps the pressure (and air) and the engine uses the amount of air that has been recorded to work out ign timing and fuel however the amount of air in the system is much much less that what was recorded so it goes into a stall
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1871172
so in summary cars with no bov or one that is too tight, aka those with really loud turbo flutter or vl turbo woop woop wooop sound is causing damage to their turbo one way or another, and besides it sucks for quick turbocharger response as the compressor shaft gets slowed down by the backpressure collison
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1871178
I sent an email to brett turner the engineer from GFB and in regard to the stalling he wrote back
"I have come across this problem before, it only seems to affect a handful of
R33's. The problem lies with a super-sensitive airflow meter, What I did determine is that the stalling is related more to the
spring pre-load than the atmosphere venting. I
would suggest softening the spring 2-3 turns by winding the chrome cap
anti-clockwise.
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1871307
Yeh thats all he wrote to me. Which was pretty interesting as you say because mostly we hear its the atmo venting but this can be different. I was also interested to know if a bov which seems to be running good if its doing silent damage. He didnt respond to that question hence why i thought i would bring this topic up.
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1874089
i had a blitz BOV on my 32 a while ago and i also kept the standard plumb back. Never had a problem with stalling. i think you could get away with running 50/50. try and see how you go - your not gonna hurt the turbo as youre venting the pressure thats built up. The only downside would be - your car may run a little rich and you may get some stalling issues. just adjust the BOV to a setting that seems good for the car and sounds good to you.
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1885838
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
