anyone here would be interested designing my web page in exchange for parts or modifications, or certain amount of dollars.
DJC is awsome.
RPMZ on the forums does an awsome job as well. He has done many quality sites including www.racepacemotorsport.com
Pm him or me for his number.
https://www.sau.com.au/forums/topic/102080-web-designers/#findComment-1872729
Bah - those guys are hacks.
I'll photoshop you dancing naked with Ash :D
What sort of design are you after?
What is your product or service?
Do you have a 4WD transfer case for a 1988 Lada Niva that you'd be willing to swap?
https://www.sau.com.au/forums/topic/102080-web-designers/#findComment-1874943
Do you want a basic web site with company info, or a DB driven web app?
Can you be a bit more descriptive with what you want? Also, what is your budget?
https://www.sau.com.au/forums/topic/102080-web-designers/#findComment-1885616
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
