Hey people
I recently got a set of 19 x 8 inch rims on my R34. Now the tyres are 235/35/19 all round, and have an offset of +35 which is the same as stock. The wheels were balanced etc, but when they were put on it was discovered that a 2mm spacer was required for clearence of the front brakes due to the shape of the spokes and big ass R34 front brakes. I also put them on the rear just so all was even. I have now found that at speeds over 100kmph a get a shake in the wheel, sometimes it is only slight, other times it is pretty violent.
Do you think that becasue the wheels/tyres were balance for the +35 offset, that with the spacer bringing it down to +33 the balance is out of wack and is causing the shakes. Should i get them rebalanced and get the tyre place to attach the spacer to the machine when they balance them?
As a side note, i have not had a wheel alignment since i have had the new wheels put on, could this be causing the problem?
Any advice would be great.
https://www.sau.com.au/forums/topic/102085-steering-shake-with-new-rims/
Although I would definitely get the wheels aligned (to ensure the best possible handling and even tread wear) I can't see this being the primary source of your vibration. Particularly if the only thing that has changed are the wheels and there was no vibration with the old ones.
It sounds as if the problem lay in the wheel balance and/or the spacers potentially affecting the state of balance.
Although this may sound silly, have you checked the wheel nuts ..... is it possible that the wheel(s) are loose?
the car is also lowered around 3 inches but this was happening before the lowering.
I don't think it is the wheel nutz as this happened from the word go. As in i got the car back from the shop on saturday afternoon (lowered with the wheels refitted, and drove out to mallala on the sunday and it was doing it. So the wheels would of still been very tight then. Wheel nuts do come loose with spacers but this is usually when it is a 10mm spacer type thing. It is not overly common on a 2mm spacer
Thanks for your input though much appriciated
It's either a slightly bent spacer or the stick on weights have come off straight away. Couldn't possibly be the wheel itself or the tyre. Balancing without the spacer wouldn't matter because like you said you have a spacer on every wheel. I'd also suggest getting a wheel alignment straight away, because i'm sure you don't want to be buying fresh tyres just around the corner!!!!
Have them balanced on the car, which will take the rotating assembly including spacer in to account.
As others mentioned, wheel nuts would have been my first point to check.
Just as a side note, the spacers are not legal, which you may or may not know or care.
chops
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
