Hey people
I recently got a set of 19 x 8 inch rims on my R34. Now the tyres are 235/35/19 all round, and have an offset of +35 which is the same as stock. The wheels were balanced etc, but when they were put on it was discovered that a 2mm spacer was required for clearence of the front brakes due to the shape of the spokes and big ass R34 front brakes. I also put them on the rear just so all was even. I have now found that at speeds over 100kmph a get a shake in the wheel, sometimes it is only slight, other times it is pretty violent.
Do you think that becasue the wheels/tyres were balance for the +35 offset, that with the spacer bringing it down to +33 the balance is out of wack and is causing the shakes. Should i get them rebalanced and get the tyre place to attach the spacer to the machine when they balance them?
As a side note, i have not had a wheel alignment since i have had the new wheels put on, could this be causing the problem?
Any advice would be great.
https://www.sau.com.au/forums/topic/102085-steering-shake-with-new-rims/
Although I would definitely get the wheels aligned (to ensure the best possible handling and even tread wear) I can't see this being the primary source of your vibration. Particularly if the only thing that has changed are the wheels and there was no vibration with the old ones.
It sounds as if the problem lay in the wheel balance and/or the spacers potentially affecting the state of balance.
Although this may sound silly, have you checked the wheel nuts ..... is it possible that the wheel(s) are loose?
the car is also lowered around 3 inches but this was happening before the lowering.
I don't think it is the wheel nutz as this happened from the word go. As in i got the car back from the shop on saturday afternoon (lowered with the wheels refitted, and drove out to mallala on the sunday and it was doing it. So the wheels would of still been very tight then. Wheel nuts do come loose with spacers but this is usually when it is a 10mm spacer type thing. It is not overly common on a 2mm spacer
Thanks for your input though much appriciated
It's either a slightly bent spacer or the stick on weights have come off straight away. Couldn't possibly be the wheel itself or the tyre. Balancing without the spacer wouldn't matter because like you said you have a spacer on every wheel. I'd also suggest getting a wheel alignment straight away, because i'm sure you don't want to be buying fresh tyres just around the corner!!!!
Have them balanced on the car, which will take the rotating assembly including spacer in to account.
As others mentioned, wheel nuts would have been my first point to check.
Just as a side note, the spacers are not legal, which you may or may not know or care.
chops
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
