Hey people
I recently got a set of 19 x 8 inch rims on my R34. Now the tyres are 235/35/19 all round, and have an offset of +35 which is the same as stock. The wheels were balanced etc, but when they were put on it was discovered that a 2mm spacer was required for clearence of the front brakes due to the shape of the spokes and big ass R34 front brakes. I also put them on the rear just so all was even. I have now found that at speeds over 100kmph a get a shake in the wheel, sometimes it is only slight, other times it is pretty violent.
Do you think that becasue the wheels/tyres were balance for the +35 offset, that with the spacer bringing it down to +33 the balance is out of wack and is causing the shakes. Should i get them rebalanced and get the tyre place to attach the spacer to the machine when they balance them?
As a side note, i have not had a wheel alignment since i have had the new wheels put on, could this be causing the problem?
Any advice would be great.
https://www.sau.com.au/forums/topic/102086-steering-shake-with-new-rims/
Alignment doesn't affect or cause the shimmy mxtcy is experiencing.
I suspect it's a result of the spacers not having the studs properly centred. Most rims these days actually centre on the hub, rather than relying on the wheel studs to centre the wheel on the axle.
  • 3 weeks later...
wheels are buckled??
cost around $60 each to get them rolled if they are
find a tyre shop that does ON CAR balancing.
that way they balance the whole assembly, works great.
but if you remove your wheels later on make sure mark them to fit them in exactly the same spot on the hub.
cheers Russell
I would go with spacers as the culprit. I had "slip on" spacers when I purchased the car and had a very violent vibration at 80km/h.
Got all 4 wheels aligned and balanced to no avail.
A tyre shop told me the spacers was the issue and I removed them and replaced them with spacers that had a wheel locater on them.
Reduced the vibration by 80%. But I will remember to get the wheels balanced next time with the spacers and see what happens.
In saying all that, mxtcy as you only have a 2mm spacer I would get rid of them and machine 2mm of the caliper.
yeah spacers arn't they suposed to tie the spacers on when the balence them to get it right it happen on my friends r33 they balenced the rims and just slapped the spacers on it shook like all buggery at 100kmph dodgey tyre factory!!(TTF) spacers are dodgey anyways!
when i put my stockies back on my car. i didnt know my 19s had a little plastic ring that sat next to the hub and inside of the bolt holes on the wheel, mechanic called them "locators"... anyways, i bolted my stockie on tight! and drove it on the highway, and then to vicroads (clear a defect :rolleyes:) leaving vicroads, i noticed a wobble, pulled over, and i could nearly shake my wheel off, nuts pretty much just fell out... scarey shit, lucky i noticed it before i got back on the highway...
so with that in mind, spacers with highspeed, heavy brakeing and sideways... i'll leave my wheel 3mm closer to the car!
Locator rings are actually a very good thing as they locate the wheel onto the centre of the hub, stoping shaking etc. and they aren't 3mm or anything like that, infact they don't sit out any further than the inside bore of the wheel itself. All hi quality wheels come with metal locators on them. The spacer i'm getting made up are hubcentric. Thus the spacer centres on the hub perfectly and then bolts on. the wheel then locators on the centere of the spacer hub using the biult in locators ring. and woot no more shaking.
I have same problem I bought new wheels last thurs from ozzy tyres and same thing!!! where can I buy hub adapters??? And are they legal?? I'm mid way through trying to get them to rectify my problem as its their fault for not telling me. But their no longer returning my calls!!
hey mxtcy
what i meant, the locator, which was made for my 19's stayed on, so when i put my stock wheel on... the wheel never huged the hub properly.
i was just comparing that to spacers which would be 'long term'.
however i know of people with spacers, that even drift on them no probs... unfortunatly i can't afford to take the risk
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
