NISMO PARTS IN STOCK NOW.
NOTE:
WHILE WE ARE HAPPY FOR YOU TO PICK-UP THE ITEM, WE WOULD LIKE TO LET YOU KNOW THAT WE DO NOT GIVE FURTHER DISCOUNT JUST BECAUSE YOU WANT TO PICK IT UP (I.E. SAVE POSTAGE FEE). WE DO HAVE LIMITED TIME AND PICK UP WILL AT LEAST TAKE 30-45 MINS OF OUR TIME WHICH WE DO NOT HAVE. THAT IS WHY WE ARE MORE THAN HAPPY TO THROW IN FREE DELIVERY SO THAT WE CAN FREE OURSELVES SOMETIME.
NISMO MUG - $59
NISMO LANYARD - $29 (SOLD OUT)
NISMO KEY CHAIN - $29 (SOLD OUT)
NISMO STICKER - $35 (SOLD OUT)
NISMO STEERING WHEEL & SHIFT KNOB COVER - $65
NISMO CIGAR LIGHTER - $50 * (SOLD OUT)
NISMO IGNITION KEY - $85 (DISCONTINUED)
ALL ITEM ABOVE ARE UNIVERSAL USE ON ANY NISSAN CAR UNLESS OTHERWISE INDITCATED
* Compatible with the following cars only:
Nissan S15
Nissan R34
Nissan GTR 34
Nissan V35
PICTURES:
NISMO MUG - $59
NISMO LANYARD - $29
NISMO STICKER - $35
  • 3 weeks later...
I HAVE IN STOCK NOW THE FOLLOWING NISMO MERCHANDISES
ALL ITEM INCLUDE FREE DELIVERY OZ-WIDE
NISMO MUG - $59
NISMO LANYARD - $29
NISMO STICKER - $35
NISMO IGNITION KEY - $85 **
ALL ITEM ABOVE ARE UNIVERSAL USE ON ANY NISSAN CAR UNLESS OTHERWISE INDICATED
* AVAILABLE IN STOCK FOR POPULAR NISSAN MODEL
** AVAILABLE IN STOCK FOR POPULAR NISSAN MODEL EXCEPT S15 AND R34
Hey I would be interested in the nismo key, how much to send to christchurch, NZ?
postage extra $10.00, plus insurance $7.50
insurance is compulsory. i hate to lose stuffs overseas
leo
  • 2 months later...
' date='30 Jun 2006, 11:00 PM' post='2299946']
hey
im after some nismo decals (the one which go down the side of the car and on the bonnet) to suit an r33....
im not sure if u can get them for an r33
if it is available. i sure can get :D
' date='3 Jul 2006, 11:55 PM' post='2302885']
cool, im also after nismo gauges im not 100% sure if they still make them, i guess if they are disscounted you cant get them?
if they are discontinued. i cant get them. if not, i can get them :banana:
  • 1 month later...
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
