Just Boost It Posted January 16, 2006 Share Posted January 16, 2006 is there much effort needed to get this kind of power?? please shine a light Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/ Share on other sites More sharing options...
Spook's_Skyline Posted January 16, 2006 Share Posted January 16, 2006 (edited) good exhaust fmic turn up boost powerfc fuel pump Edited January 16, 2006 by Spook's_Skyline Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1872035 Share on other sites More sharing options...
gtst4d Posted January 16, 2006 Share Posted January 16, 2006 You will need a 3 inch turbo back exaust( get one of those split dumps from the guy on this forum), fmic(can get a good cheep one from another guy on this forum), a fuel pressure reg and a Power fc ( get it of the same guy that sells you the fmic). Hope that helps. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1872038 Share on other sites More sharing options...
chrissso Posted January 16, 2006 Share Posted January 16, 2006 really cheap? Chinese ebay turbo dump + 3" exhaust + bashed cat. chinese copy ebay intercooler simarks boost controller Jarcay DFA. Please note that the dump pipe might split and the intercooler might not flow and cool enough. You get what you pay for. Just save up. However, simarks boost controller works well, and so does the DFA, if you put it together right. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1872056 Share on other sites More sharing options...
Bass Junky Posted January 16, 2006 Share Posted January 16, 2006 How much money? $3000-$4000 including fitting and tuning, depending on the components and the quality of work you want. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1872147 Share on other sites More sharing options...
Driver Posted January 16, 2006 Share Posted January 16, 2006 (edited) You pay for what you get. If you do it on a budget you wont get quality.. Edited January 16, 2006 by Driver Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1872210 Share on other sites More sharing options...
SAMFISHER Posted January 17, 2006 Share Posted January 17, 2006 You don't need an aftermarket fuel pump or fuel pressure regulator. I have HKS style dump pipe & exhaust, R34 intercooler, K&N panel filter and Power FC with boost controller kit. Made 207 rwkw (hub dyno) at 0.7 bar (10 psi). Total cost including tuning approx $3,400 ($NZ) Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1872598 Share on other sites More sharing options...
cerci Posted January 17, 2006 Share Posted January 17, 2006 thats what im chasing also not 2 hard 2 get there Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1872931 Share on other sites More sharing options...
dan_the_man Posted January 17, 2006 Share Posted January 17, 2006 Whats ur budget? Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1872996 Share on other sites More sharing options...
LANFOH Posted January 17, 2006 Share Posted January 17, 2006 I make that power with just: Full Exhaust Pod Filter FMIC Fuel Controller 10psi Boost. Might be a good idea to get an upgraded clutch aswell because the standard one may get cooked depending how you drive. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1873124 Share on other sites More sharing options...
Spook's_Skyline Posted January 17, 2006 Share Posted January 17, 2006 You pay for what you get. If you do it on a budget you wont get quality.. words to live by sure the fuel pump doesnt make any extra power, but i woudlnt want to push the stocko that hard, coz if it lets go, your engine aint going to like it Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1873150 Share on other sites More sharing options...
bazr33 Posted January 17, 2006 Share Posted January 17, 2006 Also helps to see a good tuner aswell i went from 187rwkw to 201, just because i was running rich as. I also have Power FC FMIC AVCR Split Dump Panel filter 3" hiflow cat Running on 12psi Some money spent on getting things were fixing up performance joints mistakes . i have been to APC, FIST, Mercury (just for power run) and Chiptorque, im gonna try matty Spry next and thats it. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1873290 Share on other sites More sharing options...
raz0r$harP.UK Posted January 17, 2006 Share Posted January 17, 2006 Don't even need a FMIC.. if you are going the cheap route an R34 GTT intercooler is only about $200 second hand and will be fine for 200kw. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1873472 Share on other sites More sharing options...
RANDY Posted January 17, 2006 Share Posted January 17, 2006 Bingo! It's the power figure i'm looking for. I've got my GTT intercooler, $30 boost tap @ 8psi, and the split dump and exhaust will follow soon. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1873895 Share on other sites More sharing options...
The Mafia Posted January 17, 2006 Share Posted January 17, 2006 then a powerfc, boost to 12psi, tuned and you'll be fine.. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1875032 Share on other sites More sharing options...
Ezz35 Posted January 17, 2006 Share Posted January 17, 2006 I just installed the front half of my exhaust, I have FMIC 3" turbo back Link ECU K&N pod 10psi Any more boost and it starts to miss with stock fuel pump, next upgrade for sure. Then onto the dyno Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1875120 Share on other sites More sharing options...
Just Boost It Posted January 19, 2006 Author Share Posted January 19, 2006 ok ive got a fmic , 3'' cat back exhaust , pod filter , and one of them turbotech boost controller but never turned it up so still running stock , also i got a power fc but still in the box hehe so is a fuel pump that important? i want 2 put a split dump n hi flow cat but if the fuel pump is more important den i should get that first Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1881527 Share on other sites More sharing options...
Spook's_Skyline Posted January 19, 2006 Share Posted January 19, 2006 i wouldnt try without upgrading the fuel pump but i love my car and dont want to hurt it Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1881842 Share on other sites More sharing options...
ghostflame Posted January 20, 2006 Share Posted January 20, 2006 no use really going the cheap way, once u start modding it never ends, youll want more power after what you've done. Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1884241 Share on other sites More sharing options...
paulr33 Posted January 20, 2006 Share Posted January 20, 2006 also it should be important to note that mods based on a $ per kw gain at the start is very high, then as you progress it drops signifcantly. the first few mods are really cheap and give really good gains. then as you progress up the power tree, usually past 160rwkw it becomes more expensive per kw gain. ie piggyback vs standalone and so on Link to comment https://www.sau.com.au/forums/topic/102107-200rwkw-on-a-budget/#findComment-1884526 Share on other sites More sharing options...
