Hey guys,
My friend is about to purchase a 1994 series 1 gtst. I've read that its best to get a leakdown test performed? and a compression test? Is this correct? Where abouts in canberra can perform these tests, and how much will he be looking at? Around $150- $200? Are these the best tests you can get done to show the overall condition of the engine? Obviously taking it to a mechanic would be a good start too...
Cheers
Dayne
https://www.sau.com.au/forums/topic/102115-buying-a-gtst-in-canberra-testing/
well to get that done you have to take it to a mechanic anyways, so after they have done the compression test get them to check over the car.
Next best thing buy of someone we all know. Then we can tell you how the car has been treated.
As to where to get read the were to get skyline serviced.
quick reference for you. Trojan / Integra / Pro Engines. All very good, trust worthy
Edited by race_snooze
Alright, The car has been to integra before... Brian, the owner of the car is apparently off SAU but ive never seen him post much, apparently works with Richard. I'll post a link up to the car, and if anyone knows much about it let me know.
I will get my friend to speak to Brian and organise a time to take it out to ed to get it checked. Thanks for the reply mate:)
Dayne
http://allclassifieds.com.au/c/ac?a=vc&i=1533137008
Edited by LO_R33
Yep, Know Brian well and we work for the same company. The guys honest and so is his 33.
I have been in his 33 a few times, it's very much stock and it is in pristine condition. This is how you want to get your 33 then do mods yourself.
I checked out the site and this car is a real steal at that price $14k). I just cant beleive how cheap skylines are getting including GTR's.
I'd get any car I bought checked out by NRMA or a very trustworthy/good mech.
Pressure/crack and cylinder compression testing will give you a good indication but there are still no garauntees. Take mine for example I had it checked by two different garages and all the tests you could dream of. Some times shit just happens and you cant see it comming.
SiN
Yup - bought the car, havent had a chance to post on here yet, as we have been to busy driving it around:P
A place in garren did the testing on the car, though didnt do what we asked for - they wrote up on the certificate that the car had 135psi in all 6.. but everyone knows no car has exact same compression in every cylinder.. and they didnt perform a leakdown test either..
Doesnt matter, the car surely does go well... i'm sure he'll come on here soon and introduce himself:)
Dayne
I thought it was a little low, and suggested that it was a little low too. Will re-do another compression test though with my own tester, just need to set aside a few hours. I wouldnt of paid $170 for someone to write that on a peice of paper though.
Dayne
Dayne
dont get me wrong as i said all cars as they get older will drop and maybe the tests were not conducted correctly. I guess ultimatly as long as they are consistant across the board you dont have alot to worry about
My GTR had 155 in 5 cyls and 150 in the other when I bought it.
I've been told upto 5% variation is nuttin to worry bout.
yea as i said from what i have always been told its better to have them consistant across the board than 5 high and one really low :P
Yeah, but what shits me is pay $170 and they didnt even do a proper compression test, where they write down what cylinders got what. i.e 1 ~ 148, 2 ~ 145, 3 ~ 147, etc etc. They just said all cylinders at 135psi. Which is what worried me a little. Anyway, the car seems healthy so it doesnt matter:)
Thanks for all the feedback guys.
Dayne
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
