Guys;
most of us are aware of the crushed sill (not chassis rail) syndrome afflicting R32 GTRs - and maybe other models. I'm talking about the flattening of the spot welded vertical seam forward of the front jacking point, behind the front wheel arch. hope that makes sense.
usually happens when the thing gets jacked, or lifted on a 2 post hoist, and just about every 32 GTR I've seen has had this happen.
has anyone come up with a surefire way to fix it? i'm sick of having to tell people not to lift it on the sills - either they do it anyway or I spend the day wondering if they've taken notice.
there's got to be a way of making a permanent professional repair. a search has revealed that others have had the same problem but not if a good repair was carried out.
i haven't seen that section cut open to know if it's even really fixable - seems to have the robustness of an eggshell so maybe a couple of 'no jack' stickers is the best defence - for those that even look before they jack.
any ideas?
regards
Edited by Scooby
https://www.sau.com.au/forums/topic/102145-crushed-sills-on-r32-gtr/
i just use a shifter to streighten them out
i think they bend in when the car is to low and scrape on the gutter or something???????
To answer these in the wrong order...
Don't use a shifter - if you want to do it this way get yourself a set of wide nosed multigrips. They lock in place making it much less likely you will damage your car or yourself.
The blokes at the pits don't really care about the rocker panels (Technical term), but can get a little worried about bent up chassis rails. They also get a bit concerned with signs of rust in the rails & particlarly if they have been bent & refilled with any sort of body filler.
one of my rails is comletly crushed, so i bought a new one from nissan for about $200 and willbe getting it replaced. the rest of the rails are also bent in through the center but nothing major.
when i get them fixed the guy wont cover them in anything so the guys at the pits can see he's done a good job. then ill get them coated.
im real worried they wont let the car pass though :P
The outer sill panel is welded to the car at both ends. The panel shop cuts the existing sill out an welds a new one in. I'm pretty sure we're on the same page because you couldn't pull out a chassis rail with multi-grip but could give it a good go on a sill.
When mine was welded in the panel shop was going to cut out a section of the rear panel but ended up fitting a new one. You'd need to paint afterwards to tidy up. If you are just pulling it out rather than replacing, then sure, no paint. My car seems to have had rust cut out of the sill on the driver side. A really dodgy job with a terrible weld job. I'm really pleased we found it and replaced the sill, it looked shocking, I'll see if I can drag out the pics.
I still have the rear quarter glass, it's just taking up space in the garage :P If you're interested Scooby, please shoot over a pm
  • 6 years later...
Resurrecting an old thread here. I am also suffering from the typical crushed sills from my car being lifted on the sills when on a hoist. I want to get my sills repaired/replaced, but want to stop them from getting damaged again once fixed.
Any ideas?? My mechanic generally only uses the sills on the front of the car, as he lifts the rear of the car using part of the rear suspension (the rear lower arms I think).
Has any one here done anything to strengthen the sills, or do you lift on different points ( other than the sills) when on the hoist??
I see in the R32 GTR manual, they use some sort of rubber block with a cut out for the sill to lift the car from the sills. Has anyone used something similar??
Any assistance/ideas appreciated.
Anyone??
Anyone??
For me Im thinking to straighten the sill as best i can with the multi grips.
And then cut and remove sufficient space for the Pads on the car hoist.
Obvioulsy cleaning up, rust proofing and painting the area.
To get it back to how it rolled out of the factory then yes will have to buy new sills and replace.
Then tell every shop you go to not to use the sill area to hoist the car up when working on it.
Perhaps you could make the rubber blocks to take with you to the shop?>
Thanks Richard. I was also thinking of straightening the sills out, then cutting some out for the hoist pads. Will also rust proof, then paint etc. Just hate the look of my crushed sills and the thought of rust creeping in there. Yes, paranoid I know!! :yes:
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
