Item:1997 R33 GTS-t Type M Series 2
Item Condition:Very good
Reason for Selling:Building a house
Price and Payment Conditions:$25,800 nego - price drop by $2,200!!!
Extra Info: Factory ABS, A\C
Year: 1997
KMs: 32,000 (aftermarket speedo) - Only 3,000km have been done in this country!!
Colour: White
Transmission: Manual
Mods:
Engine:
HKS GT2835 Pro S (integral wastegate) 0.64 exhaust housing
HKS Stainless Steel Tubular Manifold
HKS Intercooler
3" HKS Exhaust (Turbo back)
Greddy Inlet Manifold
Nismo Adjustable Fuel Pressure Reg.
HKS 550cc injectors
HKS Air Filter
Apexi coolant surge tank
Custom Aftermarket alloy radiator
HKS oil cooler
HKS oil filter re-locator
Tomei Multilayer Head Gasket
Tomei Timing Belt
Tomei Pro Cams 270 degree cams (biggest you can get for an rb25)
Tomei Solid Lifters - extremely expensive conversion and is needed for the big cams
Tomei Valve Springs
Tomei Adjustable cam gears
Cusco Oil catch can
Tomei Fuel pump
N1 Oil Pump
HKS F Con V pro (AFM less)
Drivetrain:
OS Giken TS2BD Twin plate clutch
Nismo Slave cylinder
Enkei 17x8 front and 17x9 rear RS evolution wheels (approx 3000km on the tyres)
Tomei 2 way LSD
Project Mu Brake pads
Suspension:
Tein HA height adjustable and dampner adjustable coil overs Shocks
Tein Adjustable Caster Rods
Cusco Adjustable front strut brace
Cusco Solid Rear strut brace
Cusco Master Cylinder brace
Nismo Front sway bar
Nismo rear sway bar
Interior:
Greddy Pillar Pod
HKS Oil temp gauge
HKS Water temp gauge
Greddy Exhaust temp gauge
Greddy Boost Gauge
Momo Race Steering wheel
Blitz Type R Electronic Boost Controller
Trust FAT Turbo Timer
Standard Series 2 Interior in very good condition.
$900 dollar alarm system with remote paging system
A GTR front bar has been purchased for the car to replace the standard front bar and will be supplied with the car. Why do all hard work and spend all the money when you can buy one already done and save thousands ....
Contact Details:PM me or email me at [email protected]
https://www.sau.com.au/forums/topic/102160-modified-series-2-r33-gts-t/
I assume your in rockhampton? Know someone who may be interested.... Is it possible to check it over for him on the weekend maybe? I'll pm you at a later date anyhow.
Cheers,
Bill
This car is awesome, its sounds better than any r33 gts-t on the street bar none (thanks to the head work and HKS exhaust ;)), has a very linear power delivery and potentional for more power.
I have a graph from a dyno that i don't believe is very accurate, but on it it made 230rwkw on it, yet the car can is faster than cas that have made 250+rwkw on other dynos..
Edited by ookami
still for sale .... c'mon ... people import a stock series 2 for 20 grand but won;t pay an extra 5,800 for a car with $30,000 worth of mods!!! You people are crazy .....
Very interested BUT I'm in Brisbane...not quite interested enough to fly up there to check it out. If I was in Rocky I'd be over there in a flash.
The mods look good though.
How's the tune for Australian fuel and temperature?
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
