Hey all,
I'm about to verge into travel mode and am off loading my car for sale.
Its a 1989 ca18det silvia manual with around 130000k's. It makes 150rwkw at 12psi boost from a power enterprise turbo. Many other extra like 17's, coilovers etc. The paint needs attention in places but the car runs well and fine. If anyone wants a cheap quick run-about pls contact me on 0402 099 162 (and just say if you need photos or anything).
Price is 6 grand but I can be flexible with that (instant discount if paying by cash). Don't be hesitant to ask coz I need to sell before I go.
Thanks,
Carlo
https://www.sau.com.au/forums/topic/102161-89-silvia-18t-6k-ono-150rwkw/
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
