Can any one tell me for sure how the G Force sensor affects things?
I have an R33 GTR VSpec. When we left the G Force sensor out the ABS and 4WD light came on and neither the ABS or 4WD functioned anymore.
( I had been told it only affected the SRS airbags)
The G Force sensor indicator glass is red, supposedly this means it's suffered a major shock. Does this mean it's stuffed? When I plug it in the ABS and 4WD still work OK.
Where is the best place to egt one form if I need onw?
Please no guesses, only tell me if you know for sure, Thanks.
well what I know for sure:
G sensor in the console is not related to airbags in any way...they might have their own inside the airbag unit
When ATTESA sees a fault ABS stops as well. Not sure why but it does.
What makes you think the g sensor isn't working. Do you get front torque when everything is plugged in? Is the ATTESA light on?
The airbag sensors for driver and passenger airbags are inside the engine ecu or for newer cars the airbags can have their own unit. Im not sure what exactly the g sensor your talking about is but id say be very careful with it, if its an accelerometer they will break fairly easily from a small fall onto a hard surface or being hit with a tool whilst removed from the vehicle.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
