So there is a lot of info on getting gtr's to run in rwd mode, and I was under the impression that stagea's were the same as 33/34 gtr's not able to easily put it into rwd mode other than removing drive shafts.
True/False?
https://www.sau.com.au/forums/topic/102172-running-your-stagea-in-rwd-mode/
From PM :)
its a peice of cake, remove a fuse in the engine bay, drive the car for like 200m just to bleed the pressure out of the front, then away you go. we have 2 customers with 4wd stags that come here. They pull the fuse out at there place then drive it in, by the time they get here, all good to go. give me a call if you are chasing some more info...
cheers
b.
milanco pro dyno
(07) 3390 8133
Yeah I read this thread but didnt think it worked for Stageas..?
Also people seem to think it is easier to remove the shafts....?
http://www.skylinesaustralia.com/forums/in...showtopic=52486
Tried that with both the RS4 and the 260RS, you will to remove the driveshaft. The fuse pull works perfectly on the R32 GTR and GTS4.
Edited by RBNT
Drop the shaft if the only way
I hate the 4wd sometimes, is it easy to drop the shaft?
Trust me man, you dont have to drop the shaft. If the stagea seen at willowbank was white with odd looking chrome wheels, body kit and milanco stickers on the rear windows, then that is the car that we tune on our TWO WHEEL DRIVE DYNO. Geoff (the owner) was out at the track on wednesday night..... awd stageas can be tuned and run on a 2wd dyno.
I understand you CAN do it, but what about if you SHOULD do it like that?
How does driving the car bleed off the residual pressure on the clutch packs?
I have been told that yes you can do this fuse method in Stageas, R33s and R34s but you shouldnt as the way the system is set up (Unsure of those details it was a while ago) screws up the clutch packs unless the front drive shaft is removed..somthing about the shaft still roatating and wearing some other part down (Damn my feeble memory)
^^^ what he said. The R32, A31 Cefiro and C33 Laurel are the only ones with an AWD system that totally disengages when the fuse is disconnected/switched off etc. R33's, Stageas, C34 Laurels, Y34 Gloria's, Cedric's and Cima's and R34 all have a newer transfer system which dosen't totally disengage. You CAN go for short runs in quasi RWD mode with the fuse out, but a couple of guys found the hard way what doing a full track day in "RWD mode" does to the R33 GTR gearbox.
I couldnt get either of my Stageas to run real rwd. I tried driving for a while and it just wouldnt disengage. Wasnt doing anything wrong, just wouldnt go rwd for me.
I guess a more pertanent question is Why would you want to, esp in a Stagea, unless you wanted to go to a skidpan day, but even then, I would much prefeer trying to 4wd drift ON A SKIDPAN than rwd........?
I mean it is designed to drive all four, so other than being able to tune it on a 2wd dyno, I dont see much point in it....?
Yeah see I am over the whole drift thing, I drifted the crap out of my old r33 at Queensland raceway and since I have resigned not to flog the crap out of my stagea, I dont think I'll be drifting it on a track anytime soon.
But I am very interested to get it onto a skidpan so that I can have a go at 4wd drifting. Last time I went with my r33, the instructer had a pretty worked STi and he took me for a ride and it was sooooooo wierd going past the 90 degree angle and pointing backwards and then have it just straighten back up, was quite different then rwd drifting that is for sure :w00t:
Last time my stagea was on a skidpan, Gary could not get it to drift, it had stock suspension and the auto in it at the time, but no matter how hard he yanked on the park brake, it would go to slide out and then just straighten back up, looked funny, but damn he got some great times on the motorkana section that day!
But there has been just a couple of additional bit put in it since then, so still waiting on my tune and then I'll be looking for a skidpan day to give it a go :P Personally I dont think I'll need or want to put it into rwd to drift it, the wieght and length would make it harder to keep on the drift wouldnt it?
Hi all... in issue 15 of HPI a chap that had one of the first stageas in the country said he made a simple 4WD bypass switch...that works on stagea's, GTR's (didnt say models) and 260RS's...and theres a pic of him doing a burn out to prove it...would seem a lot easier than these other methods.
i pulled the fuse in mine and went for a quick cruise. found that it does disengage the fronts, no worries. (even with the auto it got the rear tyres spinning).
i did find that my rear tyres chirped like crazy taking slow, tight corners though, and turning while reversing is a bitch. it turns out that it locks that back diff. i have no idea why. i know that the atessa drives opposite front and back wheels (front left, back right, or front right and back left, depending on traction, unless you engage the central lock). would it lock the back two so that it still has two wheels to send power through? beats me.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
