Ok my turn to have a crack. Firstly my Stagea is a 260RS so it is a 33GTR driveline.
All three times my Stagea has been on a two wheel dyno we have pulled out the 4WD fuse and bled the fluid out of the transfer case, Not the line at the back of the transfer case.
After the dyno fuse back in and bleed the air out of the transfer case.
The car still smokes all 4 wheels.
The guy doing this has been tuning GTRs for years and always does it this way, I'd guess he would had a few complaints by now if he was killing transfer cases.
that seems like the wrong procedure
not sure if this has been posted yet or not but this is from the gtr workshop manual and works on my s2 rs4s
(should be the same box as yours)
It probably does work but it is definitely the hard way!! It would be easier just to drop the front shaft but the method as described by Tom above is in the manual and I have done it successfully as have many others and (like others) I have put a switch in the circuit to make it even easier.
Pulling a fuse and draining a cup of fluid is harder than removing prop shaft?
The method I described removes power from the ATTESA so it can't pump fluid to actuate the clutch packs and then removes the preload.
I would guess the method in the manual is pretty much doing the same thing via the ATTESA ecu.
  • 9 years later...
So anyone else been doing it this way? What’s the correct way these days 🤣my atessa is playing up and I want to sort my dyno day out instead of going back and forth with diagnostic trying to fix the attessa system..
Well firstly, good searching.
I'm not convinced there is a definitive answer (noting pipster11 quotes a translated workshop manual which is a good sign).
The accepted knowledge on the forums is that in 33 and 34 platforms, even with the electronics off there is still some potential drag on the clutches inside the transfer case. That means that even if the front wheels don't turn any more, the transfer case clutches themselves may be slipping and causing damage (requires a rebuild to fix). My guess is that people who have said it works OK had worn transfer cases already and they may not have much 4wd in the first place. To be safe I take the driveshaft out if I am putting the Stagea on a 2wd dyno, it is 4 bolts and out it comes.
In the 32 platform the setup is different (slower) and it is OK to electronically disconnect 4wd (remove the fuse, use a 4wd controller to turn it off etc)
Sweet can you directly tell me what fuse to pull and if I need to flush the attessa fluid?
I will tell my fabricator to pull the driveshaft for me because he’ll be sending the car straight to tuner for the dyno after fabrication.
Edited by SLIXK
Don’t ask
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
