Hi all,
Just wondering if you guys have heard of or use Nulon Product's
E.g Engine Oil, Product Additives .. etc
Especially the E20 "Nulon Performance Engine Treatment"
it is recommended for Turbo charged engines.
http://www.nulon.com.au/
Any feedback would be greatly appreciated
Kind Regards
Steve
Edited by smok3y
https://www.sau.com.au/forums/topic/102199-nulon-products/
I'm pretty happy with their Injector cleaner. Haven't had a chance to fully evaluate the E20 - only had it in for about 300km before a broken piston assisted the deposit of the sump contents all over the RH engine bay (via dipstick pipe).
https://www.sau.com.au/forums/topic/102199-nulon-products/#findComment-1874201
its known as "snake oil" and if you put it near your car your crazy.
run a search on ptfe or teflon additives through google, then tell me you want to put it near your car.
if it was good, don't you think oil companies and car manufacturers would use it in the first place...
Infact save you the time.
Read this article, tells you all you would ever need to know about ptfe.
http://www.oldengine.org/unfaq/additive.htm
https://www.sau.com.au/forums/topic/102199-nulon-products/#findComment-1874669
Only product I use is their Pro Octane Boost - and only when I am doing track work.
In a comparitive test done by Fast Fours magazine it was equal first for increasing the octane value of fuel.
Good track insurance.
https://www.sau.com.au/forums/topic/102199-nulon-products/#findComment-1876812
We use Nulon assembly lube on every engine we assemble. I couldn't recommend it highly enough. We don't use it on pistons or rings but all bearings, valves, cams etc get a coat of it. We've never had a problem with an engine having bearing or cam damage on start up, it's cheap insurance when someone else will be starting the engine and you don't know if they will crank the engine to get oil pressure before it starts. You would be suprised to know how many mechanics don't do this. The oil should be changed withing the first few hundred km anyway and then you can rely on the oil you use.
I don't use any oil additives once the engine is up and running, I think the oil manufacturers know more about oil than I do and they know what to put in it. Who is to know if the additive will work properly with the other additives that are put in the oil when it is made. You may reduce the effectiveness of the oil you are using by using additives.
https://www.sau.com.au/forums/topic/102199-nulon-products/#findComment-1879201
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
