Hi all,
Just wondering if you guys have heard of or use Nulon Product's
E.g Engine Oil, Product Additives .. etc
Especially the E20 "Nulon Performance Engine Treatment"
it is recommended for Turbo charged engines.
http://www.nulon.com.au/
Any feedback would be greatly appreciated
Kind Regards
Steve
Edited by smok3y
https://www.sau.com.au/forums/topic/102199-nulon-products/
I'm pretty happy with their Injector cleaner. Haven't had a chance to fully evaluate the E20 - only had it in for about 300km before a broken piston assisted the deposit of the sump contents all over the RH engine bay (via dipstick pipe).
https://www.sau.com.au/forums/topic/102199-nulon-products/#findComment-1874201
its known as "snake oil" and if you put it near your car your crazy.
run a search on ptfe or teflon additives through google, then tell me you want to put it near your car.
if it was good, don't you think oil companies and car manufacturers would use it in the first place...
Infact save you the time.
Read this article, tells you all you would ever need to know about ptfe.
http://www.oldengine.org/unfaq/additive.htm
https://www.sau.com.au/forums/topic/102199-nulon-products/#findComment-1874669
Only product I use is their Pro Octane Boost - and only when I am doing track work.
In a comparitive test done by Fast Fours magazine it was equal first for increasing the octane value of fuel.
Good track insurance.
https://www.sau.com.au/forums/topic/102199-nulon-products/#findComment-1876812
We use Nulon assembly lube on every engine we assemble. I couldn't recommend it highly enough. We don't use it on pistons or rings but all bearings, valves, cams etc get a coat of it. We've never had a problem with an engine having bearing or cam damage on start up, it's cheap insurance when someone else will be starting the engine and you don't know if they will crank the engine to get oil pressure before it starts. You would be suprised to know how many mechanics don't do this. The oil should be changed withing the first few hundred km anyway and then you can rely on the oil you use.
I don't use any oil additives once the engine is up and running, I think the oil manufacturers know more about oil than I do and they know what to put in it. Who is to know if the additive will work properly with the other additives that are put in the oil when it is made. You may reduce the effectiveness of the oil you are using by using additives.
https://www.sau.com.au/forums/topic/102199-nulon-products/#findComment-1879201
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
    • What I’m saying is that I never heard of a non gtr 34 coming with a cooling panel stock or factory option. Maybe they might’ve I don’t know
