hi guys having some troubles with my 96 gtst, well symptoms are when i give full pedal turbo spins up to full boost, and it seems like its retarding, full boost and goes nowhere. there is no intercooler pipework leaks, bov leaks so there is nowhere for the air to go, maybe fuel issue??
ideas on what to check for/ anyone experienced similar???
any help apprciated cheers
https://www.sau.com.au/forums/topic/102237-no-full-boost-no-power/
I;d see if you have a bugger fuel pump, or maybe a stuffed turbo.
Take it to a mechanic if you aren't sure about what you're doing.
yeah my mates a mech, and he is going to be piised off because driving it around to his place just then and its driving fine hehe and i know how mechs like the eratic probs.. cheers
Sorry not sure exactly what you are trying to say.
So it hits full boost, and the car goes nowhere. When it happens is the boost falling off or it stays on full boost? Also, does it still rev out cleanly but just doesnt feel strong?
Could be simply clutch slip?
Might also be the reason it was fine when your friend looked at, as when clutches first start to show signs it needs a bit of heat to start slipping.
Edited by FATGTS-R
when i accelarate on boost, turbo spools reads 7psi on my gauge but doesnt pull, feels like timing is retard but is not,def not clutch slip i no what that feels like
revs good, idles smooth drives good of boost, only notice it when i sink the boot in
are you reading off the stock r33 gauge ? because its not in psi if you are reading from that one, its in mmhg, +7 is 700mmhg which is 1bar which is too high and the stock ecu is doing its factory protection mode
i got no form of boost control
stock boost 7psi/ .5bar if you like
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
