Item: Complete RB20DET from 1990 R32 GTSt
Item Condition: Motor is in perfect condition, 95000 k's on clock no weird noises etc, any tests welcome (compression test etc)
Reason for Selling:RB25DET, oh yeah! ;)
Price and Payment Conditions:$800, taking offers, email me :rofl:
Extra Info:Comes with all manifolds, turbo, injectors, coilpacks, etc etc complete working motor, Will through in ECU aswell if someone wants it, dont have loom.
Contact Details:For quickest response email me on [email protected]
Any questions dont hesitate to ask. :)
Really need to sell asap ;)
Cheers
Edited by Memph
https://www.sau.com.au/forums/topic/102245-complete-rb20det/
Anyone make a reasonable offer.
motor needs to go!
its just sitting at the mechanics, and he wants it out of there :)
and i dont want to cart it back here, just to have to cart it to someone elses house :)
hehe
heres your chance for a cheap complete motor. make an offer :)
if anyone wants to come pick it up from teh mechanic. they can take it for 650!
thats a steal. considering it comes with turbo, air con, injectors, coilpacks. you could probably sell seperately for more.
Carn fellas. Want it one by the end of next week. even this week would be awesome.
  • 3 weeks later...
hmm sorry mate im out i have purchaced an AVC-R instead :cheers:
Guys i have seen this motor it runs well and is in great condition.
Legit reason for sale.! Good luck memph with the 25 conversion!
$500 for the complete setup !! Bargain
-Jay
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
