Hi Guys,
I have a r32gts-t and I have noticed my lsd is starting to wear out.
The diff has been whinning since I bought the car and only since got a
bit louder.
My car is at the mechanics at the moment and I getting it looked at today.
I will be getting all the bits that are worn out replaced.
Although im not too sure what to do with the lsd.
I have been recomended a mini-spool and when considering rebuilding the diff and getting a mini-spool, its far better off than spending almost double in a japanese lsd.
I would like some opinions regarding the lsd and what people think of mini-spool.
Thanks
Mark
https://www.sau.com.au/forums/topic/102276-diff-opinion-needed/
  • Replies 40
Thanks
AFAIC mini spools should be left for the track, and I think are illegal in most states. Besides the car will be a pain to drive at low speed/parking.
If you have a clutch pack LSD centre it should be possible to restore it by re-shimming and it's unlikely to be responsible for the whining, which is probably due to damaged bearings or a shot crown wheel and pionion set.
Hi Guy's,
Thanks for the opinions.
Yes Ash it has been a long time! Hows ur beast?
I've just done some research and I don't think a mini spool would be good to go for, I don't like the fact that its locked even under de-acceleration.
Does anyone know where to get a mechanical centre from?
Ash where abouts did you get your diff done & will the lsd last?
Thanks heaps so far guys
take care
Mark
nengun can get nismo/cusco lsd's 1.5/2 way but I dunno how long it would take to get one to your door.
If you decide to go with a jap diff centre I would suggest on a 1.5 way.
I have a cusco 2 way and it is very tight indeed, It can be a real pig at times.
Edited by RedDrifter
Hi RedDrifter,
Thanks for your advice man!
I think I will be looking at a 1-way or 1.5-way although I would like to know the difference between the two.
As far as I know the 2-way would be more suitable for track/drift cars.
Is there any places in melbourne that would stock a centre?
Thanks
Mark
Hi RedDrifter,
Thanks
Mark
This should explain how they work and the difference between the 3 types of lsd.
Well It did for me anyway. :D
http://www.cusco.co.jp/english/e_lsd.html
I wouldn't bother rebuilding the stocker, its only going to wear out again 6-12 months later if you drive hard.
Buy a mech LSD for around $1100 and you won't have to worry about changing it again if you look after it properly.
Go see Henry at RMS Motorparts and tell him Sam from Geelong sent you, he'll look after you...
give greenline performance a look.
Great prices, and aparently shipping is pretty quick
http://www.greenline.jp/
good luck.
they have brand name lsd centres for ~ $700+
I am going to grab a couple when funds come in.
Another place you could try are Garage 13,
Thanks guys for all the advice!!!
My diff has worn out today :(
It started rattling and making noises, luckily only a block away from the mechanics!
I got it there safely, thank god.
I will go ahead with rebuilding the stocker, I was told by Ben a race pace that they are mechanical anyway. Obviously nothing compared to the after market options.
Although come to think of it the stocker isn't so bad, to think about it its lasted around 13 years on my car and who knows how bad it was treaded in Japan. I can tell you for sure that when it arrived the oil was putrid and the diff made noises when reversing. Ive maintained it and to be honest it has had a bit of a work out on occaision. To last as long as it has, I think its pritty damn good.
I love the drivablility and it has never been a problem since the lsd has started to wear out. I think it will be great to have a fresh diff. And at the moment unfortunately I don't have the funds to indulge in an aftermarket lsd, then on top of that replace what may be damaged.
Although in the distant future if the lsd starts to wear out, at least I will know that the one I will purchase will be going into a pritty fresh diff that will be well looked after.
Thanks Heaps Guys
Mark :P
I'm going a GTR Mechanical clutch center in my R32 GTST.
They go for around $500-$650.
I'm taking the pumpkin to the diff people and having them shimm it up a little, at the same time they will check it out, if its near nackered I will have the wreckers replace it with another item.
It won't be too tight as to feel like an aftermarket mech. lsd but something streetable. :(
Edited by Cubes
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
