I was told by Ben a race pace that they are mechanical anyway.
stock r32 gts-t diffs aren't mechanical btw, they're viscous (unless nissan released a couple of freak gts-t's with mech's..... who knows)
  • Replies 40
Hi Guys,
I finally got my car back last thursday!
Im very happy with the rebuild, works very well!
In my situation the rebuild was the better option because my gears were a bit worn and the pinnion rod was snapped, so now my diff is nice and fresh.
We will see how the lsd works over time and maybe look at an after market item. If so I'll know the rest of the diff is nice and fresh!
I also got a 12 month warranty with the rebuild.
Thanks for all you advice and opinions guys.
Take Care
Mark
  • 4 weeks later...
hey guys,
im very confused and dont know what to opt or my gtst 32.
basically the car is street, i like to drive in the hills alot, needs to be daily driveable-ish.. can handle a little bit of inconvinience.. and i want it to slide hard every now and then when i tell it to... whats the best option?? i was offered a nismo 2way for my car, but i dont know if it wat i really want/need.. what do you guys reckon?
A clutch type diff is always shimmed to adjust its tightness.
VLSD's on the other hand are a total different kettle of fish.
A gtr diff can go for as low as 450 right up to around (nisswreck) 650.
Obviously with the nisswreck diff you get to swap it if its too worn or stuffed.
I'm not sure on the setup cost.
I am going this route once I drop new valve springs and smaller head oil restrictors in. Head off job :woot:.
the only real time i find my nismo 2way getting on my nerves is in the servo carparks with the shiny concrete. Then it squeaks like a biatch.
Id only replace it with the gtr mechanical, a 1/1.5 way or the s15 helical centre. But i like the way it is now :woot:
I have had the Kaaz 1.5 way mech diff installed.
The difference is marked!
The car powers out of corners now hard as. At deca on the weekend, I got zero single spinning. much better drive.
but, if ya wanna hang it out, as I really do, the diff is great. very controllable and easy.
so a 2way wont be deathly in the hills and spit me off a cliff somewhere... they are pretty reliable.. as in work the same every time..
unlike some diffs ive noticed will work one time and then not another you have to be prepared for anything depending on what mood its in..?
i dont mind a little bit of gayness from it coz its going to be mainly weekend/cruising/latenight stuff so yeah
Go the 2way.. Its not like you will loose money on it as they hold their value well. :blush:
If its a little harsh and you get paranoid when cops are looking when the inside wheel chirps around roundabouts and in carparks then look at a gtr mech diff.
You'll get used to it. I drive mine daily with a lot of car park use (at uni) so there's no way I would put up with a aftermarket 2 way especially if it shudders and chirps the way the nismo 2 way does. :geek:
But if it wasn't for uni I could probably put up with it, not sure if the other half would be too happy about it though. :S
Does anyone know what kind of GTR diff centre would suit a SII R33 Sedan 5 speed? Im thinking of replacing/rebuilding the diff and putting in the GTR diff centre, as it sounds like a good compromise between vlsd and mechanical. Maybe i will wait a while and see what Cubes results are like :).
cheers
Evil
Whats a "AFAIC" mini spool? I've been searching for a mini spool for my 33 gts-t diff for quite some time now and cant find one at all.... anyone have any ideas?
Basically a small device that replaces the centre of the diff, be it an open diff or possibly lsd and it locks the diff, kind of like welding only removable.
  • 1 month later...
Hi Guys,
It has been a little while since I started the thread.
I just wanted to share something I found quite interesting.
While I have been enjoying my fresh diff a lil while ago now I was chatting to my mechanic and he told me I had a GTR centre!!!!
Could someone please tell me the advantages??
All I know is it doesn't have clutch packs like the gtst ones.
Thanks
Mark
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
