whast the fan switch which sits on the lower right hand side of the steering wheel??? is it the ac fan, mine has never worked, tried t have a look why and its a myserty, the light never worked (seems it should be in working order when I took it out) and when I switch the ac on, the thermo fan sitting infront of the ac doesnt spin.
My AC does work but pretty poor so am wondering if thats why, + I have a huge intercooler sitting in front + an oil cooler.
Sorry I have been a posting whore latley but have plenty of time on my hands for the next couple of weeks. What better way than to spend it working on the car.
https://www.sau.com.au/forums/topic/102287-whats-this/
i dont have a switch there its just a plastic infill panel piece. Not sure what it would do ...probably nothing important. i dont think it would affect the ac ....
the thermo fan is probably another problem not related the the button but probably related to the ac not working so well. Is the thermo fan still connected ...? considering all the other stuff which has been place in front of it .......
https://www.sau.com.au/forums/topic/102287-whats-this/#findComment-1876509
nah it's not for the fridge...it's the the air purifier in the middle of the back parcel shelf...mine has it as well...you can actually hear it working if you leave the car on "Reds" and switch it on and off...took me about 2 weeks to realise...only noticed one day sitting in the car puffing on a blunt...
https://www.sau.com.au/forums/topic/102287-whats-this/#findComment-1882456
Yes, it's an "air purifier", but my ass... not a very effective unit if you ask me... pull mine off/out as it was rattling and giving me the shits (need fresh air, open one of 4 windows located on Cefiro or 4 door Skyline :lol: ), but you could probably use the switch as a 12V power source and open/closed circuit.
https://www.sau.com.au/forums/topic/102287-whats-this/#findComment-1883404
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
