Contact Details: prefer pm
the usual deal, stuff taking up space and needs to go. mostly s13 and rb20 parts but also other random bits. parts good if have to return vehicle back to stock for defect, or drift damage, etc <_<
miscellaneous
*full set of 6 gtr injectors. 444cc. $300
*16" davies craig thermo fan. brand new. sold
*z32 front hubs/spindles. sold
*s14 complete rear cradle, lsd diff, includes control, toe, camber, etc arms, hubs, 5-stud spindles, calipers, rotors, drive shafts, handbrake cables, swaybar and subframe. $500
*r32 gtr front hubs/spindles. includes dust cover/shroud and some brakes lines and ABS fittings, wiring. sold
rb20/25
*s2 rb25 turbo. little shaft play, bit noisy, otherwise fine. perfect for hi-flow. 200
*r33 series 2, rb25det radiator. mint condition. sold
*rb20 stock intercooler. (including piping, connectors and crossover pipe, if u want it) sold
*rb20 turbo, mint condition. a bee's dick of shaft play, nothing abnormal. no chips, leaks etc. also with elbow and accuator. sold
*rb20 turbo, some shaft play exhaust wheel otherwise fine, suit rebuild (eg. racespec gt2530, etc), also includes elbow and accuator $100
*rb20 water pump. used but good still condition. spins freely. no shaft play. $20
s13
*hicas sender unit and some lines and fittings
*air con vents, black, rare mint condition, no cracked fins, full set. $100 ono
*180sx front reo bar, straight, not cut for cooler, etc. $100
*s13 silvia front bar. mint! new green paint $100
*lowered king springs suit s13, sold
*koni rear struts (red). actually really good condition. $100 ono??
*SR20 front calipers, rotors, plenty of pad/rotors meat left. sold
*CA18 front calipers, rotors, also plenty of klms left. 3 sets. $100
*ca18 brake booster/ master cylinder
*ca18 intercooler, 2 of. $25
*front control arms, inc ball joints, sold
*castor rods $60 each
*power steering pump, $100 ono
*air con compressor, blower fan/ box, etc. will separate.
*ca18 radiator x2
*radiator shroud x2
*hubs/spindles, sold
*struts, springs. (aftermarket unknown brand) sold
*ca18 auto engine and gear box
*front pipe
*engine van and viscous coupling
*ca18 tail shaft (manual). $100
*air box, snorkel, piping (turbo and non turbo)
*ca18 afm (same as sr20??)
*indicator stalk, good condition, not faded, scratched etc.
*waher/ wiper stalk, also in good nick
*dash parts: air con control unit, vents, centre console, steering surround, dash surround, etc, etc.
*brown parts: dash, kickpanels, under steering wheel, glovebox, etc. offers
*wiper motor
heaps more parts available, too many to list, will add more later as i sort them out, if you dont see it there just ask, probably got it. i dont know what a lot of stuff is worth so offers accepted on items not priced, most prices are negotiable, i want to make room and free up sum cash :D .
180sx for sale
also for sale: a very straight, clean bodied, grey 180sx (1989), ca18det, auto. clean as!!! paid $7k...offers. check out car add forum for further details :P .
http://www.skylinesaustralia.com/forums/in...7entry1893037 sold
also looking for a s13 silvia, want reasonably straight but show condition definitely not required.
have a motor to put in it so want as minimal as necessary so prefer no motor/box/etc. must be in brisbane area.
cheers,
Edited by rb20inside
https://www.sau.com.au/forums/topic/102302-s13-and-rb20-parts/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
