1992 R32 GTSt Skyline
Body Etc:
Black => Red, Full Respray In Japan
GTR Bodykit => Alloy Bonnet & Guards, Genuine N1 Front Bar, Rear Wing
Rolled Rear Guards to accomodate tyres
Sunroof
ABS
Engine & Other Mods:
RB20DET
Coustom high flow seiera turbo made by ATP curently running 1.1 bar (NEW)
TRUST 3" Front mount Intercooler
GREDDY Intercooler Piping
Custom Made ECU with spare reprogrammable EPROMS
300ZX Air Flow Meter
600HP Bosch Motorsport Fuel Pump (NEW)
Exedy Ceramic Button Clutch (NEW)
RB20DET gearbox (NEW)
3" Turbo Back system with removable silencer (NEW Dump Pipe and Cat)
Aftermarket LSD(?)
Suspension:
Adjustable height coilovers
Adjustable Castor Bushes
Adjustable Camber Bushes
Wheels & Tyres:
F: Zelda Tri Spokes 17x8" => 235/45/17
R: Zelda Tri Spokes 17x9" => 265/40/17
Interior:
Alpine Double Din In Dash 3 Disc Stacker/Tape/Tuner with 6ch 4v pre-outs, Equaliser, Track and Station Titleing
Greddy Boost Gauge
Genuine GTR Steering Wheel
Alloy Gear knob
$20,000 ono
Call Adam 0419 504 338
https://www.sau.com.au/forums/topic/10232-modified-r32-gtst-for-sale/
  • 6 months later...
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
