If you want the very best, NEO synthetic oil is the go. It's the only oil the public can buy which is derived from a fully synthetic diester. Their gear oil is specified by Hewland. Club racers & motorsport pro's use this stuff. Amsoil is also very good. It used to be derived from a full synthetic diester, but they changed the recipe. Then you've got your regular oil companies (Shell, Castrol, Mobil etc).
Nissan specify 7.5w-50 or 40 (can't remember which) in the Jap owner manual. Don't use cheap sh1t oil...
https://www.sau.com.au/forums/topic/10233-oils-ant-oils/#findComment-161377
NEO is awesome stuff, if you've got plenty of $$$ ~$175 for 5L :eek:
Any of the good quality synthetics are fine, ie Castrol R, Mobil 1, Shell Helix Ultra & so on. Most importantly change oil & filter every 5k. If you do track days etc probably worth doing changes more often.
I use Motul 300V CHRONO 10W/40 . I just did an oil change, 5L cost me $85.
http://www.motul.com/uk/produits/competiti...auto/index.html
Redline is another very good, costly, choice.
http://www.redlineoil.com/frames/engoil.htm
Prices - http://www.gearbox-racing.com/redline2.html
https://www.sau.com.au/forums/topic/10233-oils-ant-oils/#findComment-161491
I have always used Pennzoil but Shell bought it out and now they are mixing in their blends.....:rolleyes: Will start using a new brand that has a base so pure that it is totally clear infact the oil is sooo good they don't make synthetic as it doesn't compare to the normal stuff.
https://www.sau.com.au/forums/topic/10233-oils-ant-oils/#findComment-162183
Guest Nismo_Freak
Hey... they have 2 road tracks now!
But they call up different drivers to race on the road circuits LOL!... NASCAR sucks as-s. I'll take my rally and GT enduro thank you.
As for oil... Mobil 1 is good and relatively cheap, but Amsoil is the best for the buck IMO.
https://www.sau.com.au/forums/topic/10233-oils-ant-oils/#findComment-162418
Wow! It must be top stuff if this fella says so...
"Royal Purple is the best protection that money can buy!"
- Mike Kloeber, crew chief for Clay Millican, two-time IHRA Top Fuel Champion and winner of 11 event titles in 2002.
....sarcasm people, sarcasm. It is good though. http://www.royalpurple.com/rethome/rethome.shtml
BTW Gimme rally any day :rolleyes:
https://www.sau.com.au/forums/topic/10233-oils-ant-oils/#findComment-162467
Originally posted by 2rismo
BP, yeah that's what i meant...  no excuse for being that dumb.
Whatever the completely FREE one is that i get from work.
hehehe...
thx ed
free is always good.... :uh-huh:
I saw Visco 5000 and I'm like...huh? maybe I should use that :rolleyes:
where do you work BTW?
https://www.sau.com.au/forums/topic/10233-oils-ant-oils/#findComment-162559
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
