denham do u have the parts? ie. a spare mem card and a network adaptor??
if u do come around and bring an original PSone game and i'll do it for u in about 5 minutes like i did my mates the other day
I was about to go out and get it but i got a bit side tracked my the new celsior i just picked up :D
Yup i've discovered they are readily available however I have a Slimline PS2 which has the network adaptor built-in, so what do I need now in order to get this all 'happening' ?
can't be done on the PS2 Slimline as easily unfortunately, as it doesn't have a HDD port built in. You CAN hook up an HDD to the slimline if you solder the pins of an HDD connector cable in though. I dunno if you cbf soldering 40 wires into a space the size of your little finger.
gtfo? $100 for an adapter? I bought mine from EB for $20.
yeah i got mine for 25 from EB but on EBAY people are buying them for over 100AUD because u cant buy them anymore as Sony havent made any since the release of the slimline and no stores can order more stock.
so if u find some there is some profit to be made if u can get them for under $50
i need 2... for my mates
