Does anyone in Adelaide have their dash cluster out of the car atm, or a spare cluster?
I want to try plugging a known good cluster in to my loom to see if the dash lights playing up is something to do with my cluster or the car. Alternator is working fine, wiring to the alternator has been replaced (battery light now never comes on) but the other lights (radiator, door, brake fluid, windscreen washer, foglights) still come on when the engine is running
Cheers
https://www.sau.com.au/forums/topic/102375-adelaide-callout/
did you forget to fit some wiring back up when you changed motor's Adam???
Take it to jaustech and get them to look at it, it could be a million and one issues, if you've replaced all the wiring between the alternator/starter motor/battery, and its all done up, make sure its not earthing out on the brace for the plenumn as mine was...otherwise seek professional help!!
New battery, still making 16+ volts... Bloody mechanic swore to me that it was charging at the correct rate :(
So its off the road till I get the alternator out... but its too damn hot to do it :D
Does anyone have any hints for getting it out of the car with minimal fuss?
So its off the road till I get the alternator out... but its too damn hot to do it :)
Who worked on the car Adam???
To get the alternator out, do the usual stuff, like belts yada yada, but take the whole bracket off that bolts to the motor otherwise there just isnt enough room to get the alternator in and out...Trust me i've done it like 3 times in 3 months, its a bitch but you get good at it :)
I must be a retard... I cant even get the belt to loosen. Tried undoing the bolts on what I think is the tensioner and then tried to get the body of the alternator to swing around but no luck.
Theres also some part of the air con or something above it, do I need to remove that aswell?
Oh, and I put a brand new battery in it the other day, its bloody dead flat and I only ran the engine with it in it for a short time :P Something weird is going on with this car
Are you sure you don't have some sort of a drain somewhere within the car?? No old alarms or anything like that electrially in there that would cause a drain??
Air con is all on the other side mate....You've gotta undo the nut on the front of the tensioner, and then you can undo it, its pretty easy, just stand back and work it out from looking at it....
I've never had any battery drain problems until after they did the alternator wiring and since then its drained two batteries... no alarm, no lights or anything were on, face of the deck wasnt in the car so the deck couldnt have been on... what else can use power? I'm fairly sure the interior fan switched off when I last stopped the car.
I undid the two bolts on the tensioner thing b7ut nothing would budge after it was undone
Ok are you working friday or will you be around??? I'll come around and show you how to get it out...I don't rekon its your alternator though, cause the car still run's doesn't it once its started??? I'd take it back to jaustech, tell them its now drained 2 battery's and to fix it properly like they should've the first time...and or take it to an auto elec, cause to me it sounds like you've got a drain somewhere
Wasnt done at Jaustech, my mechanic did it. It was making 17 volts when it was revved, so the regulator does need to be done, but yeah, I think theres something weird going on aswell thats draining it... but it would have to be something to do with the wiring that they touched as nothing else was touched before it flattened the batteries overnight. I do think it cooked the first one though.
Friday... Working from 5 I think
Give up? I got the bloody alternator back in there :P
Didnt put the plug in properly and it burnt itself out when the plug fell out, but I put it back in.
Sold it to a friend, the guy that bought Paul's Paul Newman a while ago, he wants to put a big turbo on it and stuff like that. I bought his MX5 Clubman. Missing the FJ20 power, but I'm happy with it.... Just gotta keep telling myself that... :(
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
