Do the motor registry and/or Police take notice of these "engineers certificates" ?
I went through the pain of getting my vehicle over the dickson pits and registerd just before I did the motor in (3 visits). As rego is expensive I asked a lady at the registry that if I cancelled my rego (cash back) and the car was off the road for less than 12 months would I have to go over the pits again. Answer NO.
Truth turns out to be YES. Now I'll have to do a shit load of visits and depending on the mood and the guys on at the time I am sure I'll get a reaming.
Edited by Sinista32
Oh Sin, I'm sure you'll bend over backwards for him.....
No they dont. Police can issue a defect notice for a stock standard car if they wish, its your job to take it to Dickson and get it cleared.
And on that note, Dickson can also reject engineer certificates if they still believe the car does not meet ADR's.
And MYSHY, all 15 year imports have to be engineered to get rego. Cars that came in under a compliancing scheme like mine and sinista's dont have to have engineering certificates for registration (thats what the compliance plate is for).
Nik, have you ever heard of Dickson rejecting an engineer's certifcate before?
If you have, do you know for what reason?
Yes I have, was on an imported car with Blitz technospeed wheels. The engineer had issued a certificate saying it was safe etc ok. Still didnt change the fact the wheels were more than 15% larger in rolling diameter than factory, which meant they were not ADR compliant, and hence rejected.
I was talking to a guy from the Northern Territory at the nats. He had a VL commodore with a RB26 in it. I asked about engineering and he told me he didnt need it! He said that up there, its all done on displacement. So technically going from an RB30ET to a RB26DETT is a DOWNGRADE!
I dont know if he left out any info but if thats true im going to retire to the NT!
Edited by noakespg
Amaru. yes you are correct about the 15 year rule if your car is modified in any way but not if your car is standard you dont need an engineer
you can do all the work yourself and get the side intrusion etc put in and checked
Mainly just saying that you can get anything engineered, but the cops can still anything they want to your car :D
They rejected my engineer's certificate, actually. They said the certificate mentioned "two seats" when obviously the car had four. It took a phone call from the engineer to say "yes it says two seats on that line, then on the next line down it says 'and another two seats'". :(
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
