i have been told that i need new castor rod bushes and also need new castor rods
my question is this
i already have new whilteline castor bushes here at home and was going to buy these
http://cgi.ebay.com.au/FORGED-CASTOR-TENSI...1QQcmdZViewItem
would it just be easier to guy these
http://cgi.ebay.com.au/NISSAN-SKYLINE-R32-...1QQcmdZViewItem
the nismo ones look a little different to the newer ones so that why im a little confused. and id also save a little bit of money on the nismo one because they already have the bushes...is this correct?
Edited by DLuded
https://www.sau.com.au/forums/topic/102394-caster-rod-help/
I don't like the look of the cap screws supplied with those cheaper gerneric brand castor rods (first link). You should also take a look around on the fourms, there is a lot of negative info on Castor rods with spherical bearings as well.
https://www.sau.com.au/forums/topic/102394-caster-rod-help/#findComment-1888373
  • 3 weeks later...
If your after performance and adjustability i'd go with the first link no bushes needed just the two bolts through the control arm and castor rod (either side) then a wheel alignment. Or cheaper get the second link arms and replace bushes (good as new but no adjustment).
Good luck
https://www.sau.com.au/forums/topic/102394-caster-rod-help/#findComment-1943195
get fully adjustable pillowball rods
heaps better
BETTER? Not if it's used on the road regularly
Much more NVH
Higher likelihood of cracking the front subframe due to lack of compliance
Sphericals wear out rapidly as they have no dust/dirt/water protection
Good quality spericals are costly to replace
Breakage is not uncommon
Illegal in most states
Maybe for a track car only, even then they are illegal for most classes of circuit racing.
:P cheers :D
https://www.sau.com.au/forums/topic/102394-caster-rod-help/#findComment-1954608
