  • Replies 152
Are you planning on making these in the Blue 4x20 display?
Was sceptical of these at first because i have the impakt one.... but congrats man, these now look far superiour.
If your making them in the 4x20 box... (smaller i hope)
Then count me in.
unfortunately the blue 4x20 displays are negative/transmissive screens. this means they rely solely upon the backlight to provide lighting, and any external lighting will cancel out the backlighting. without the backlight (or with cancelling external light) they will appear black and unreadable. so unless you only drive at night, the screens will be unreadable during the day unless put in something which receives very little natural light.
traditional 20x4 lcds are also slightly more than twice the height of the current screen ive got. means that u have practically no useful mounting positions compared to a lower profile screen (which can be mounted on steering column, dash near windscreen, or sun visor (maybe?)). as im sure ur aware, finding a place to mount one of impakts devices that wont mean ur taking ur eyes completely off the road to look at it, isnt too easy.
one alternative is the crystalfontz low profile 4x20 screens: http://www.crystalfontz.com/products/2004k/index.html
if u find a suitable enclosure, these could be mounted inside a DIN slot. they are wide temperature which is good (as are the ones im supplying) but the viewing angles from above arent so good (so youll need it close to eye level to read them easily - ie not a low DIN slot).
just an update on what ive done/havent done:
done:
main sensor display
keeping track of max values
button inputs (i dont want to hear the word "debounce" for a long while!)
main menu
reading error codes
device info
some options stuff (eg reading saved options on startup)
still to go (probably in this order):
clear fault codes
peak values viewing
options setup
time trials
and most importantly, i havent build any devices yet (hardware wise), but this isnt much of an issue compared to finishing the device firmware
as with ellie, i'd also be very interested in a device that you could plug some external sensors into as well (such as an oil pressure sensor, oil temperature sensor, exhaust temperature sensor) for an all-round unit, so you don't have to have seperate gauges for all of those, but could view them all in the one unit.
The problem with running boost displays through an electronic readout such as this, would be it is constantly changing at a very fast rate, which makes it very hard to read, and you would need an extremely high refresh rate on the unit as well. You're much better with an analogue gauge for that type of display.
good point about refresh rate - oil pressure or boost pressure arent really useful on digital display as theyre changing too quickly
but like ive said previously, i cant do anything without technical specs on whatever sensors u would be using (eg k-type thermocouple is known format for temp reading, but as for pressure, no idea)
no probs mate, keep up the good work, the units look fantastick BTW.
So just for my satisfaction, what features will it have in the end.
details on p6
NewKleer, is it possible to include knock sensor value?
hopefully all these (as post above linked to)
i snuck a "400" into the time trials section, which is for a 400m time trial - this might not make it in if i cant accurately enough measure distance (which is hard without an accelerometer or access to trip meter). i think i can get close which is why i put it there, but ill find out soon enough. although i am a tad concerned if it is in there, that people will find the need to do a 400m run on public roads, but u could do that already with a stopwatch, so hopefully common sense will prevail
if i somehow have too much time, ill see if i can setup some config to allow economy to be L/100km, which requires setting up ur injector CC rating. like the 400m thing, i dont know how accurate
details on p6
while the knock sensor value itself cannot be read via consult, i came across somewhere that said bit 7 of address 0055 will tell u if the ecu is using knock maps or not - so ill see if i can add ability to read this
bar graph would be acceptible way to view it (allows u to glance at it to read boost, which is analagous to normal analog gauges)
however, wont u want to read sensor values and boost pressure/oil pressure at the same time without having to switch between them on the device? in which case itd make sense to have seperate gauges/devices.
anyway this wont be in the initial release, we can talk about it after uve got ur device if u are still convinced u dont want to keep a separate boost gauge.
I'll go back on what I posted and say that boost and oil pressure should deffinately be monitored on seperate analog gauges but if someone can find some K-type temp sensors to monitor oil temp and exhaust temp, THAT would bw very handy.
I wanted an all in one display of boost pressure, oil temp, oil pressure and water temp all at a very high sample rate to give very accurate, quick read outs but that isn't what this tool is for as far as I can see!
I will definately buy one of these because of the dianosis (and to a degree) tuning data it can provide.
If things go amiss, you can see at a glance a fault or a dud sensor.
Gauges have thier place as you can see raedings in your periphery vision fairly accurate were as a digital reading requires you to focus on it!
Can I ask what the point of time trials are? Don't be mistaken, I think this is a fantastic product but am unsure of what this function is used for that you couldn't get at the drag strip?
i definitely still want it to be able to monitor k-type thermocouples so that can become an addon for anyone who wants that. and i also have generic voltage input monitoring on the todo list (to read any 0-5v input) for after the initial release sometime (i do have to work on an update to my consult software first, however)
as for the time trials, ask people why they buy g-tech's for and u probably have your answer there. it is nothing u cant get at a drag strip, but then not everyone goes to a drag strip. i also want to see how accurate distance measurements can be, as this may tie in with more improved economy monitorying/trip meter type functions. and if i go so far as to implement the 400m time "just to see" how accurate it will be, i may as well leave it in
for thermocouples, maybe this would be appropriate?:
http://www.jaycar.com.au/productView.asp?ID=QM1283
ive no idea how ud set it up for oil or exh temp. intake (before and/or after IC) would be useful and easy to set up?
Edited by NewKleer
some things that i was thinking of before:
if we do end up going down the path of having external sensor monitoring, it may be needed to do it on a seperate unit.
also, i see you are having a peak hold function in the unit... i run one of Impakts interfaces, and it has peak hold, but it only seems to be on what is displayed on the screen... i.e. you can't cycle through other readouts that weren't visible on the screen at the time and see their max values...
will you be able to cycle through all the readouts with yours and see their max values, or only the ones that were visible on the display at the time?
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
