if u can grab the ecu serial number (23710-XXXXX) then i can probably check when ur ecu is from. most likely if u havent wired up the consult port ull need to do that, but thats only a minor issue.
  • Replies 152
not yet...got word back from one of the two places i contacted about getting it custom made (this one in the US) and i should get an estimate on how much it would cost from them soonish.
still finalising some of the hardware - ive decided on just serial consult interface capability (was thinking of usb, but decided the usb if at all would be an adaptor onto the serial - have already tested this in its basics and its fine, but will cost an extra $20 and probably diy to put together). want to have the pcb made so that all future functionality i might put onto the device is there to start with - ie room for eeprom to store data, buzzer for alarms, etc
ive found a decent LCD (viewing angle 50 from up, 60 from below, and 40 each side which is by far best ive seen, good refresh time, also is wide temp which is great) which ive got a couple of to test with. just hope they are kept in stock as i bought 3 of the last 8, but it might take quite a while to get more in
desktop and ppc software is on hold while im working on this. havent really started ppc app aside from just testing some stuff will work on it. good thing will be that knowing how to make it look will be harder than actually doing it
be working a bit on trying to get a beta of the desktop version available today
got a first quote back on the enclosure being custom made, going to be around the 30$ in large quantities (ie 50-100), which i guess if i cant get anything better will go with it. around $15 more than what i budgeted for, but still have another place to check out so will see if i can get something better there
Edited by NewKleer
still unsure if ill be able to do that, will take a while to write up a construction guide and whatnot, and troubleshooting any problems will be hard. construction itself might not be too difficult so i might just do that myself
essentially it comes down to whether i think ill save more time doing it myself or not whether i can offer it as a kit. wont rule out anything yet though
at this stage i think best case scenario would be end of march for when i get things all ready by (either diy or assembled), but have been busy at work lately so havent had much time to finalise stuff like pcb layout (which then effects the enclosure production).
cool take your time.
Attention to detail will pay off for you- its proof to the rest of us that you're going to have a top product at the end of it :P
  • 1 month later...
here's an update, have made a prototype. which removes a lot of the extras, but am just testing the main screen and will soon be able to test the integrated consult interface, just need to wire up the serial plug.
as you can see the size is still quite compact and am on track to make it of similar dimensions to whats shown there.
shot taken on angle as i had no contrast adjust setup on lcd yet (and straight on was just like all black). whats shown there is standalone and only has the consult plug coming off it.
Edited by NewKleer
  • 3 weeks later...
need to have a draft pcb made for the enclosure to be done (so they can make sure everything fits). i hope to have it done by end of month. then maybe 1.5-2 months till enclosure is done, and at the same time id get final pcb and components ready.
unfortunately due to enclosure costing more and having to get the pcb's done elsewhere to the normal place, current estimate is up around the 175 mark, however this shouldnt change much (and no chance of it going beyond 200).
hardest thing is getting the time to get pcb done with work and uni being flatout. i just want time to stop for a week!
heres the prototype pcb that sits behind the lcd. the lcd "plugs" into the very left "rectangle" box on this thing (and thats the only connection to it, so replacing it will be easy). ill be getting this made soon for testing (about 5-10 of them), so fingers crossed i didnt make any mistakes.
there are 3 buttons - the left one will be (whenever i add the functionality) the "command" button, and the next two will be the add/minus or up/down or whatever buttons. you can then see the switch roughly in middle, here you switch it to left to use the display like normal, or to the right to use it as a consult interface. theres also a lot of future expanability in the board (a lot of places i can wire other stuff in) so hopefully ill only ever need this one layout for anything i do
will be ordering parts soon, and if the first prototype boards i get have no issues, then i can get a full batch done and get the enclosures made (roughly 6 weeks from then is when enclosures might be done).
the novelty of blue wears off quickly once u realise how hard it is to see in daylight and on angles.
but any standard sized (182x33.5mm) 40x2 module can go in. just this one im getting will be wide temp and very good viewing angles compared to most.
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
