  • Replies 97
Posted Images
hello there
I am interested in the rear battery cover (as on the pic below)
See image
Would you happen to also have the "screws"/"nuts" (as per the pic below)??
I live in Melb.Kindly quote me a price including shipping ;)
Edited by anexiole
chasing the center console lid if the spring clip bit is still in working condition???
cheers
$20.
Will you take $50 for the dash?
Okay.
Adrian
hello there
See image
Boot trim is sold complete. Thanks.
Adrian
can you get back to me on the indicator piece and the left shock, thanks mate.
also a price on the air-con condensor and radiator.
Edited by SECUR1TY
hey mate do you have the tailshaft yoke? I will come down from sydney and pick it up tomorow...
yep - come get it.
SECUR1TY - Indicator stalk $60 as posted earlier - shocks all sold now. Air-Con condensor and radiator.....$200
Adrian
sorry i was looking for it last night i have already picked one up sorry mate i needed it asap. I'm sure it won't be hard to sell though il let people know.
GL with the sale of the rest of your gear.
is there any way you'd meet half way for this?
Whole car being stripped for parts - quick sale
Wollongong, NSW
All panels except bootlid damaged - mechanically great
Bought car for parts - lots left
Pickup only preferred
RB25DET, 5-speed, all driveline, some interior, 4 x standard S14 rims, dash components, headlights, tailights etc
ONLY contactable via email: [email protected]
Adrian
Do you have an undamaged front bar and what condition are your headlights/how much do you want for them?also the S K Y L I N E badge thing between the tailights,intact? how much?
Edited by BOVed
SECUR1TY - Half way to where mate? :)
Front bar has minor damage - headlights are in good nick - they work and with a bit of turtle wax on the lenses, should come up fine. Boot garnish is available too.
Front bar $90
Headlights $300
Boot garnish $50
how much for the float inside the fuel tank
sorry mate - wrecked the car with the tank in it. :)
im from bankstown so anywhere between where you are and here
I'm sure we can work something out. You mean the radiator/condenser for the air-con yeah? Not the radiator??
Adrian
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
