  • Replies 97
Posted Images
radiator AND aircon condensor, i woudnt pay 200 for just the condensor!!
thanks for the offer NXTIME, ill let you know mate.
Edited by SECUR1TY
Hey Adrian
How much for:
rear passenger side lower control arm
the aircon line from the aircon compressor to the condenser.(small one)
delivered to 2486
pm'd aswell ;)
Cheers
Replied to your very cheeky offer of $800 delivered. Back to sleepy-dreamland with you!
drivers side light? and radiator brace
Both gone - sorry.
Adrian
Both gone - sorry.
Adrian
Then i offerred you a sleepy $1000 del aswwell..
as i said.. "all jap sell em for $1250.. so i went from that..
Hey Adrian
How much for:
delivered to 2486
pm'd aswell :D
Cheers
:P
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
