SOLD
Tomei Cams - 260 degrees x 9.15 lift:
Australia:
As New:
Change of mind:
$700.00 plus freight:
These are Spec B cams and were purchased from Japan and have seen little work. They are for the R34 GTT. Will suit the RB25 DET (NEO) engine. I am prepared to trade for a set of the Tomei Spec A cams with a cash adjustment (either way):
Contact murraybain@dodo .com.au or call my mobile 0400006864:
SOLD
Cheers
Muz
Edited by Muz
https://www.sau.com.au/forums/topic/102436-tomei-cams-rb25-det-neo/
Hey Muz.
Just curios why you want to change to Spec A?
What supporting mods would you have been putting with the cams?
Hey Bass,
I have all the usual mods and had bought these cams thinking I might go for a larger turbo but have since changed my mind and will go with a high flow (like you and Adam). After reading Adam's (Abo BOB) thread on here, I figure that the Spec A cams will be enough and still leave me with the very sweet idle I have at present.
Is this line of thought correct? Happy to be told otherwise.
Engine Mods: LARGE ARE intercooler. Z32 AFM, PFC, Nismo fuel pump, Nismo fuel reg, Nismo 480cc injectors, Nismo Twin Plate Clutch, Nismo 3.5 inch exhaust system, Nismo Timing Belt, Apexi Air intake, HKS Oil cooler. Some of this stuff is still waiting to go on (italics) and is just sitting in boxes on the garage work bench.
Almost forgot to mention the crowning engine bay improvement piece .... A genuine BASSJUNKY Radiator Air Flow Guide. :(
Happy to continue the discussion.
Cheers
Muz
Edited by Muz
That Radiator guide is good for at least 50rwkw. Why do you wven need cams?? :)
Well, my cam idles now at about 950rpm, sounds angry at the moment because of the turbo and dump pipe I had put on, so I'm getting it quietened down via a new read muffler this week. the Idle is smooth enougt I guess. It's sure as hell not a stock sounding idle, but it doesn't rattle or burble like a big V8 does with bumpsticks.
I'm super keen to see your power/torque/boost graph when you get it.
I think maybe you will make similar power, but maybe earlier and not hold it for as long as mine does (our to 7800rpm). Iff only it was as easy as swapping cams I'd do the exercise myself!!
On the freeway it's fairly inefficient. at 3100rpm, that's when she's most confortable crusing, but seeing as there aren't any 120 limited roads in Melbourne, it's a bit of a pain. Hopefully the Step A will be more efficient at lower revs.
BASS OUT
Thanks Bass,
Looks like I might have sold the cams to a guy in Germany as no realistic takers here in Oz. I'll post the graphs when I get it all done. Now to find a set of Spec A's.
Cheers and thanks
Muz
Edited by Muz
  • 3 weeks later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
