  • Replies 53
Posted Images
its OK Jef
I loved it when you drove past those two girls and gave it a roar. We were about 30 meters in front and we still heard your car and the girls scream! :lol:
GOLD!
Also for those of you that think the screamer is loud - i do agree. BUT if its too loud youre too old!
Edited by sproosy
I thoroughly enjoyed that actually. Darkz - that run was good :D
I had an awesome time both before the cruise and after, talkin in maccas for like 3 hrs :P
Jeff - your screamer sucks. Me & Paul ended up closing our windows and putting the aircon on whenever u were around.l
Oh and 4th gear owns on the gtr :O
yes yes.... it was a good run low 11 sec R33 GTR vs a auto GTT with 180 speed limiter... OFOUCRSE U OWED ME U WENT UP TO 240 u hoooon!!!!!
I dont know what you're talking about :wacko:
Mona's car is damn quick, I dont care what anyone says. Kept up with me through the straights :D
Plus I think Mona's a better driver than me :ban:
  • 3 weeks later...
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
