R31sc!!
Guest INASNT
i swear i was just talking to one of ur relatives... it took almost half an hour to get the idiot to remake a connection.... it took the level1 tech before he had to xfer it 25 mins just to get the username and his problem... then the guy tried to argue with me that the issue was on our end... funny how ppl with $2 modems, win98 which hasnt been formatted with 4 years, assume its always on the isp end.
some ppl just have no logic sense what so ever.
https://www.sau.com.au/forums/topic/10262-r31sc/page/2/#findComment-162121
mabye u should enrole that guy in 1 of your special school classes to help him out! :lol:
https://www.sau.com.au/forums/topic/10262-r31sc/page/2/#findComment-162123
i would but ur uncle wont make it past the first test... spelling his name. one thing "special" school ppl have to be able to do.
nothing can help ppl like that... thats why theres no hope for u.
https://www.sau.com.au/forums/topic/10262-r31sc/page/2/#findComment-162129
STOP HIJACKING!
Bloody post-whoring-hijacking-INASNT!
How rude! lol
So... inark, have you got a better description of this car?
I assume it's an R31, is it a Silo, a Ti, a GX, and Exec? etc
Is it a series 1, 2 or 3 and what colour is it?
Does it have mags?
Have you seen the drivers head?
Got any more info than 'boy racer'?
https://www.sau.com.au/forums/topic/10262-r31sc/page/2/#findComment-162176
lol
well i did write up a decent description in the original post... which... went god knows where
i dont know the older model skylines very well...
it was all white... p plates... the rear lights were different to some R31/30s as they were painted too so that it showed the stovetops more... it was a non turbo by the sounds of it and the exhaust note was terrible. very dark tint...
https://www.sau.com.au/forums/topic/10262-r31sc/page/2/#findComment-162357
he would have to go to special school to think he can out run me lol
actually half the ppl at my special school arent that dumb... must be another one of inasnts relatives... altho even then i think he failed colouring between the lines.
https://www.sau.com.au/forums/topic/10262-r31sc/page/2/#findComment-162483
Guest
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
