Hey guys.
I've been looking at second hand coilovers on eBay. I'm come across a few now that have said "This suspension was designed for an R32 but will fit an R33" or vice versa.
What I want to know is, in people's experiences are theses items actually interchangable?
One eBay'er who I asked the question to said that the only difference is that R33's suspension is designed to be a little harder due to the extra weight of the car but due to the suspension packages being pretty hard anyway, it should fit on my R33 quite well.
I'm just a little confused. Any insight it much appreciated as I'm really keen to get something decent handling for my car. 240rwkw is all fun and everything, but when you can't corner it kinda sucks.
https://www.sau.com.au/forums/topic/102626-r32-and-r33-coilovers/
the strut tops are diferant.
but you can rotate them to suit. the shock body is longer in the 33.
but if there height adjustable that can be fixed.
the valving shouldnt mater because youl probably change the springs anyway. hopfully they use a standard 65mm id or 60mmid spring( not the ghey taperd tein type)
The R32GTST fronts will fit the R33GTST.
GTR's fronts are not interchangeable with GTST's, the spring rates are way too high.
The R32GTST rear shocks wil not fit R33GTST, the R32 shocks are much shorter.
:( cheers :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
