looking to buy an f-conv (not pro). im in Japan at the moment but i cant find anything about them. the guy who is selling it says its easy to tune but i dont know if it needs software(like the pro) or what the perameters are or what functions it has. its cheap and it is pre programed for my gts4 so im really keen to find out
more. it comes with a book which i shouldnt have any troubles getting translated, but soft ware? hand set? minimal japanese cant ask these questions!
any help apreciated.
https://www.sau.com.au/forums/topic/102643-f-con-v-info-not-pro/
I the situation that you install in in an R33 or R34, I believe it operates as a piggyback computer. The tune can vary plus or minus 7 percent (stock ecu variation) and is therefore a waste of money and time, may as well have one of those shitty safc's in there... That said it will modify ignition timing but as I said it will vary due to the stock ecu making variations.
-rb25
hey all,
I've got one of these pfc f-con thingys to which i bought a while back, all these things are a bit confusing as ppl keep thinking its a power fc which bought, well all mine says on the cover is pfc f-con and says it is a programmed fuel computer system, there doesnt seem to be anything where a hand controller can be pluged into, its is a piggy back computer. Does this computer simply over ride the factory pre set fuel map and compensate accordingly to modifications made to the engine such as afm enlargement?
F Con V has extremely limited support in Australia. There are only two or three tuners I know of in Australia for it (CRD, BD4s).
For that reason alone I'd go something that is accessible by most tuners (eg SAFC, PFC with handcontroller, etc)
,24 Jan 2006, 09:05 PM]so is the pfc f-con programmable or is it pre programmed? as i said , there is no where for a controller or lap top to plug into, does it need to be pulled apart
The Pfc f-con is before the f-conv. you can get a thing called a HKS gcc to plug into it to further control fuel over the rev range. Stick HKS gcc in a google search. From what i understand of this one (the pfc) it blocks a few unwanted signals from the standard computer and increases fuel plus changes timing for increased boost specifically programed for that model of car. the gcc gives an element of customisation but is not so difficult to use, dont know where it plugs into but they are advetised a bit. if you have a a\f meter and understand how a computer works you can do teh fine tune yourself it a general interpolated ajustment to teh fuel curve between seven points on the rev range simular to the fuel ajustment function on the preprogramed microtech, but with more interpolation, some people only spin second and third hand info (not helpful guys!). saw some sites where rally cars were using them and were impressed. They are also still popular here in japan.
Still cant find info on the f-con v ! (not pro!!!)
Edited by momo
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
