Odometer
The Odometer on my car (R33) has stopped moving, the trip meter doesn't move either. Everything else works like Speedo so I'm a little confused...
I guess it’s been wound back and it hasn't been working now for about 8 months. I've had the instruments out and they look 100% fine. I just didn't have the guts to start removing the dials out of the instrument panel to look inside them for damage…
Does anyone have any suggestions?
https://www.sau.com.au/forums/topic/10266-odometer/
Originally posted by ndr
I have a standard speedo in great working order if you need it.
Neil.
My R33 is a series 1, would this speedo work in it? and if so how much?
Also if I do remove my existing speedo section out of the instrument cluster to have a futher look do you need to take the needle out? and if the needle is taken out will this effect the calibration?
Thanks guys.
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-165678
mines the same guys i have posted a thread in WA asking how i get the bloody thing to work as well! Same deal trip and odo stopped everything else working A1. Mine has also been tampered with on australian soil too so it seems (and i bought it privately and he seems to have tampered with it in the last 6 months of him having it) all it seems be able to do is rip the instrument panel out and have a look yourself or have someone look at it for you. Pain in the butt i know mine has stopped for two months now and be probably another two months befor ei get it seen too.
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-167564
FlyGuy,,,,sorry I don't know if S1's and S2's are the same,,,,I think they are,,but don't hold me to it. Changing speedo's is piss easy,,,,remove the whole cluster,then un-clip the front screen ,then unscrew the speedo itself by the screws at the back,,,reverse all to re-install. No needle work is required. I'll sell you mine for $100,,,it's in ABSOLUTE PERFECT working order. Has 78655 kays on it....
Neil.
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-168509
  • 3 weeks later...
Hi Guys,
I own a R33 gts25t and my odometer / tripometer have stopped also, and its giving me troubles since im trying to sell it at the moment as well..
A few people on here have mentioned fixing it themselves or taking the dash to an "instrument tech"
Can anyone who has had success fixing these, tell me who / where they took it to get it fixed (im located in brisbane, but if still supply name of business maybe i can find something up here that can do it also)
and/or more detail information about how you went about fixing it yourself.... any help would be greatly appreciated !!
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-192456
As I just indicated in another thread, I take all the issues with my car to (including fixing the odometer)
Gavin Woods
Auto Tech
23 Gibbs Street
Labrador, QLD
Ph: (07) 5529 2313
I know I sound like a broken record mentioning this guy all the time. But he does good honest work that doesn't cost the earth.
Yes he is at Labrador, but it only takes 30 minutes to get there.
I've suggested many skyline owners take their cars to him and all have had nothing but praise for him.
Mario, Maybe you could get the throttle body and odometer looked at at the same time?
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-192658
It didn't take long. But I normally take the whole day off work and go down and leave it with them the whole day.
But I'm sure if you ring him and work something out with him, he'd be able to give you a better idea.
I can't comment on the price because it depends on how much work is involved with doing your car.
https://www.sau.com.au/forums/topic/10266-odometer/#findComment-192782
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
