I need to get a hold of the little black box that sits in the drivers door that has the relay controls for the drivers side window.
The dang relays in the box have died and decided to leave my window down as a result.
So if anyone has one laying around, along with the actual drivers side control switchs in working condition, please let me know.
Thansk for you help guys :)
God Bless,
Nate
https://www.sau.com.au/forums/topic/102676-need-drivers-window-control-box/
hey nate,
My window relay is starting to make strange noises, and I've heard that there are different versions of the "black box" that you're talking about and you have to make sure if you get a new one that it has the same serial number as your old one.
Can you confirm this? Or did you just buy one and it worked? :)
Thanks,
Jason.
Jase,
the serial number was different... the lady couldn't tell me if it can off a r33 or r32. i threw it in the window and it worked sweet.
Costs 66inc GST.
I think alot of people are starting to get many problems with the auto windows only on the drivers-side... must be some common problem... who knows... drives you nuts when it happens though :) if it happens again, i will be making my oen relay and switch box as i know that the motor is always ok.
if you are ever stuck though with the window down, just throw a 12v dc supply on the motor and depending on which polarity you give it, it will go up or down.
best of luck mate, and let me know if you need anything else
God Bles,
Nate
Thanks Nate,
Can I confirm we're talking about the relay with the actual switches on top as well? My drivers switch (that one that says auto for the window) is dicky and the relay makes weird noises when you wind the window down ...
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
