hey guys
just bought my cefiro
just wondering a few q's...
R32 disc to disc rear end (5 stud) fit in cefiro without modification?
who has stereo surround for cefiro and a spare dash?
who has door trims for cefiro?
and one of my windows does not sit up on its own... any reason why? does it need a new motor?
also has anyone got series 2 drivers side tailight piece?
thanks guys,
any help would be great! :O
https://www.sau.com.au/forums/topic/102688-cefiro-qs/
hey guys
just bought my cefiro OK
just wondering a few q's... OK
R32 disc to disc rear end (5 stud) fit in cefiro without modification? 5 Stud conversion can use 32, 33 or any silvia hubs and rotors
who has stereo surround for cefiro and a spare dash? Jap wreckers
who has door trims for cefiro? Jap wreckers
and one of my windows does not sit up on its own... any reason why? does it need a new motor? Do you mean it doesnt go up, or doesnt STAY up. Probably the reugulator more than the motor
also has anyone got series 2 drivers side tailight piece? Kudos motorsport
thanks guys, no worries
any help would be great!  :(
https://www.sau.com.au/forums/topic/102688-cefiro-qs/#findComment-1886191
i can pickup a complete r32 gtst type m rear end with good cond viscous (i have a 2 way so id put that in and sell the lsd) thats almost so cheap it would outweigh buying hubs n crap (everyone overcharges)
thus im wondering... will it fit?
also my window wont stay up... glass just slides down... used tape to hold it up
https://www.sau.com.au/forums/topic/102688-cefiro-qs/#findComment-1886826
not sure on the rear cradle whether it will fit or not. If it has hubs just take them off. Saves replacing the whole rear cradle.
Window has obviously come out of its 'holder thingo' take the door trim off and have a look. (Screws on the bottom and front side of the trim, then pull carefully and it will pop off) :P
https://www.sau.com.au/forums/topic/102688-cefiro-qs/#findComment-1886926
just ripped door trim off
nothing between the skin and the door at the bottom... electrics are there but im assuming no motor or scissors... glass is there with the clips with holes but nothing in there to connect em too
assuming i need motor and scissor assembley? anyone?
btw got a nardi 330mm black classic dished wheel with r32 boss kit for sale
https://www.sau.com.au/forums/topic/102688-cefiro-qs/#findComment-1888298
If the window doesn't stay up its the regulator that is broken, here's the link on how to replace it http://www.skylinesaustralia.com/forums/in...topic=90417&hl=
Cheers
David
https://www.sau.com.au/forums/topic/102688-cefiro-qs/#findComment-1904342
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
