Hey everyone,
I seem to be having a very inconsistent problem with my car. its a 1996 series 2 R33 GTST, and every time i go for a long drive (this is when it normally happens), when i slow down and have to use first or neutral, the cars revs start in fluctuate between 400 and 1000 rpm, then occasionally it just dies. i've noticed that i happens when i have the air con on for a while.
This problem is very inconsistent though, as it may only happen once every couple of months, but when it does, its very annoying.
If anyone has any ideas on what the problem could be, or how i can fix it, it would be much appreciated.
Thanks
https://www.sau.com.au/forums/topic/102697-i-need-some-help/
This has been covered in the past and in fact in the last few days. Have you tried a search as most of the common stuff has already been suggested to try and narrow it down and isolate it. My first suggestion would be ecu reset and then check airflow meter plug / try another known working airflow meter
Hey everyone,
Thanks
I think our problems may be related some how... Except mine does it all the time :P I don't have a clue about AFM's or electrics. Will prob take it past a shop that know their RB's
http://www.skylinesaustralia.com/forums/in...howtopic=102046
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
