are you referring to this thread?
http://www.skylinesaustralia.com/forums/in...howtopic=101083
if so that's not giving me the info.
I need to know if 255 or wider will fit on an 8" rim.
Apart from this thread - http://www.skylinesaustralia.com/forums/in...howtopic=101561
one person's suggestion is not something confirmed. also note that entering 8"* resulted in no search results.
thanks.
Edited by silman
An r32 gtr came out with 225s on an 8" wheel. What Manwhor3 said is correct.
Generally, on an 8" wheel, you'd fit 225s or 235s.
It is possible to stretch 205s on. This will give firmer sidewalls.
It is also possible to fit 255s on, but I wouldn't do it. It will actually decrease the traction around the corners. Sidewalls will be really floppy. It will look like a rounded blimp.
At the end of the day though, it depends what purpose the tyre is used for though. If it is for drag only, sidewall flop doesn't matter because you're not cornering. in this case, a 255 tyre like a bfg drag radial would be good.
But for cornering, I wouldn't do it.
Of course different tyres will look different, but they will stick over the side of the wheels. I have a set here in my garage with 255s on it and I absolutely hate them.
I'm not really using these wheels, but the moment I need to, i'll be sticking 235s straight onto them.
I'm not theorising. I've used about 6 sets of tyres over the last year on different width wheels. I seirously reccomend 235 as the width. As I keep saying you can fit on any size tyre. 235 is a good fit.
If anyone actually knows about tyres, you'll know that wider does not mean more grip. Increasing the width of a tyre does not increase the size of the contact patch. Contact patch is determined by factors such as weight of the car and tyre pressure.
Inccreasing width merely changes the shape of the contact patch. Making it wider rather than longer. This gives it more lateral traction. HOWEVER by having it wider than reccomended, the sidewalls flop, thereby decreasing predictability and decreasing the speed that you can go through a corner, thereby taking you backwards in terms of performance.
Fit the right size tyre and you will love it.
On an 8" rim, i'd probably fit 225/235 for general applications.
Also, different tyres will sit differently on the rim due to their shape and construction. So just because Manufacturer A says that a 255 tyre will sit on an 8" rim doesn't mean Manufacturer B will.
Most non-useless tyre manufacturers will have a wheel fitment guide for their tyres. There's generally a 1.5" range for each of their tyres, but that's not always the case.
From my observations of the manufacturers' web sites, 255 width tyres have a minimum rim width of 8.5".
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
