Well i finally purchased a PFC and got my car tuned after all the work thats been done to it over the last year and a bit. It made 405hp which is around what i was hoping for
Here is me thinking that it will be the last thing i do to the car.. Now im trying to work out how i can squeeze out more
Dyno sheet attached.
Cheers
Edited by Driver
https://www.sau.com.au/forums/topic/102736-got-around-to-getting-my-car-tuned/
nice work...got mine dynoed at hyperdrive also this week...425@rw hoping to get more also, may need bigger injectors and d-jetro so to do away with AFM's. good power tho for your car..hope top see you around...GO EAGLES :P
haha
Under the bonnet is an n1 gtr engine with gtr turbos.. so no gt-t engine anymore.
Yeah the boys at hyperdrive always do a good job :P
The injectors and afms are at their max so they will be next on the list.
I just bought a dirt bike so i think i might play around with that for a bit first :P
  • 1 month later...
R43 GTT-R? what the hell is that :D
nice power figures though.
apart from the N1, what other mods has it got?
just the usual fmic, pod(s), exhaust, ecu?
the R43 GTT-R.. this car can fly :laugh:
n1 turbs, fmic, pods, catback + front pipes, ebc, cam gear, 044 pump, clutch, pfc
i cant remember the rest.
injectors and afm's maxed out.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
