Item:gunmetal grey r32 tail lights good condition!
Item Condition:good condition
Reason for Selling:clear lights going on * LED *
Price and Payment Conditions: 100$deliverd australia wide expres postage
Extra Info:will fit gtr,gts,gtst,gts4 etc
Contact Details:pm me
https://www.sau.com.au/forums/topic/102745-skyline-r32-tail-lights-100set/
  • 4 weeks later...
