nate can detail all of their cars... i'll just watch :D
nah they dont have a tranny stand... well i never saw one. they have engine stands.
if troy can do it in an hour... we should be able to do it in at 4... each clutch :(
  • Replies 72
2 guys. Box and clutch out, new clutch and box in, and running in less that 4 hours. Nothing more than a set of chassis stands, and two hydraulic jacks. You will need a 1 meter extention for your socket.
GTR btw.
lol shutup danny
or i'll keep that RB25 gasket kit and sell it to pay off your mums crack bill. (thats the bill to surgically fill in some of her arse crack to make it look smaller.)
we need jacks for the gearbox right? whats the chasis stands for? doesnt the hoist hold it up?
the chassis stands are to get the car in the air. That or use wheel ramps. Either way get the car as high in the air as you can.
Once you have it up in the air, you use two jacks with wheels. Not your 'I'm stuck on the side of the road, can you help me Mr roadside assist man' screw jack. Lift the gearbox up, and roll towards the engine.
they've got a tranny stand, and 2 new hoists and a whole heap of new shit since the last time you were there :D
well i have my clutch... its been sitting in the back of the skyline along with the dump, front pipe, cat and fmic for the past 2 weeks.
so hurry up biatch
nah i was refering to the factory
lol yeah i can do that kind of stuff myself :P but thanks for the offerings
alright biatch so when do u want to do this? id prefer it was a night when its not 11ty billion degrees
lol yeah i can do that kind of stuff myself :D but thanks for the offerings
dunno, i value my car :lol:
ill try and get some "experiencd"people to come down
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
