nate can detail all of their cars... i'll just watch :D
nah they dont have a tranny stand... well i never saw one. they have engine stands.
if troy can do it in an hour... we should be able to do it in at 4... each clutch :(
  • Replies 72
2 guys. Box and clutch out, new clutch and box in, and running in less that 4 hours. Nothing more than a set of chassis stands, and two hydraulic jacks. You will need a 1 meter extention for your socket.
GTR btw.
lol shutup danny
or i'll keep that RB25 gasket kit and sell it to pay off your mums crack bill. (thats the bill to surgically fill in some of her arse crack to make it look smaller.)
we need jacks for the gearbox right? whats the chasis stands for? doesnt the hoist hold it up?
the chassis stands are to get the car in the air. That or use wheel ramps. Either way get the car as high in the air as you can.
Once you have it up in the air, you use two jacks with wheels. Not your 'I'm stuck on the side of the road, can you help me Mr roadside assist man' screw jack. Lift the gearbox up, and roll towards the engine.
they've got a tranny stand, and 2 new hoists and a whole heap of new shit since the last time you were there :D
well i have my clutch... its been sitting in the back of the skyline along with the dump, front pipe, cat and fmic for the past 2 weeks.
so hurry up biatch
nah i was refering to the factory
lol yeah i can do that kind of stuff myself :P but thanks for the offerings
alright biatch so when do u want to do this? id prefer it was a night when its not 11ty billion degrees
lol yeah i can do that kind of stuff myself :D but thanks for the offerings
dunno, i value my car :lol:
ill try and get some "experiencd"people to come down
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
