Hey all, got a SII R33 and when I move the temp from 18 to 19 degrees and look at the blend door motor/actuator controller thing (on the left of the driver side foot well) I've noticed it goes full lock and blasts out hot air rather than moving gradually and allowing any variance between super cold and super hot.
Anyone else had this problem? I'm not sure if it's the little motor thing or something else.
Cheers
https://www.sau.com.au/forums/topic/102769-ac-blend-door-actuatormotor-problem/
I would assume that to increase the cabin temp by 1deg, would take a while, so it should go to full hot untill the temp increase is detected by the temp sensor in the dash.
My theory may be wrong, just sounds logically correct.
I would think it will still open fully till the sensor picks up the change in temp.
I may be wrong, but the "auto" feature controls the fan and a/c speed. So if you add a degree but keep the fan at 1/4 speed, then the heater position has to change to raise the temp.
correct... auto controls the fan speed to bring the temp up or down, and then maintain the temperature that you selected.
setting it to 24 or something will still make the unit blend the two together.
Based on that I'd be thinking that the temp sensor would be shot then... as changing from 18 to 19 degrees should not induce full blast heat, lol. I'll test the theory on the way to work tomorrow by setting it at 19 for as long as I can bare the heat!
I've never removed it and am the first owner in Aus but who knows if it was done before. Where is it located and what is the sensor looking thing at the very left of vents on the top of the dash near the bottom of the windscreen?
Not sure what you are refering to here, a pic may help things :(
Just to the right of the clock, behind the steering wheel, there is a column of slotted vents, measuring about 10mm(h) X 5mm(w). When you take the insert off you sould see a 10mm vaccum hose connected to it. Once the hose is removed you will be able to see the little sensor.
What I'm referring to looks like what a Commodore has on the dash to measure sunlight and turn on the headlights automatically. I'll have a look at what you're talking about, cheers for the info.
Tried your theory, switched it from 18-19 and waited like a mofo and baby did it just keep on pouring out hot air =D So either the temp sensor is stuffed or the blend door controller is busted and doesn't have variation, just has full lock hot or cold. Can someone please get in the driver side footwell and change from 18-19 and watch the blend door motor, tell me if it goes full lock or not.
Cheers
OK... I checked mine today, to see if I could narrow down my clicking noise..
It's a cold day today, slightly rainy. If I press "up" on 20 degrees, I hear the actuator move a little, and the air feels warmer. Each time I push it up I hear another little actuator movement, and the air gets consistently warmer until about 30 degrees... my motor was still warming up at that stage.
So... based on that, i'd say you may have a problem. I tested using the blower on "face", outside air (not recirculated) and no A/C. Tested on fan speed 1 and 2.
AND! My clicking only occurs when I turn the car on, or after that, only when I choose "feet". All the other vents switch smoothly and quietly. (gotta find that other thread now!)
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
