If i end up keeping my running gear i will enlarge and improve the sump oil capacity and anti-surge characteristics. The 4WD sump has already been installed with a boxed pickup at the bottom, which then taps into the RB30 block from the outside where the old oil-pickup used to be, this is due to the sump blocking the RB30 oil pickup. The engine is going into an R32 GTR and i want to know what i can do do improve on this. I already have an oil cooler so the oil capacity will be slightly increased but im sure other things can be done aswell
Thanks for your help
https://www.sau.com.au/forums/topic/102771-rb2630-sump-modification/
Road and maybe drag
You won't generate enough G-forces on the road to need anything better than what you have. If you are running water cooled turbo/turbos, an oil cooler is probably not necessary either.
If you are intending to use road tyres for the drags you won't need anything better than a standard sump. For radial drag tyres or slicks the most common sump upgrade we see is the Trust sump extension. This solution would mean redoing the external feed to the pickup.
:D cheers :D
I was doing some surfing around the net and came across this on the high energy website. The sump looks good, still plenty of ground clearance but some extra volume plus trapdoors. It might be worth a look http://www.highenergy.com.au
ProEngines: I just rang Hi-Energy and they said that the sump in your picture was a one off for the owners car and due to "poor casting" that they will not be making anymore.
Maybe Hi-Energy know something all the jap tuning shops dont? I doubt it but thats what they said anyway
Rather than a 'poor casting' it's more likely they had trouble cleaning it or simply didn't clean it properly, which is essential for TIG welding (and to be fair not that simple on a cast alloy sump that's contained oil for many,many years).
acid clean and abrasive blasting should clean it like new
