o, today my mate and I decided to take the bus down to Grand Plaza to grab a bite to eat. It was raining rather heavily as we made our way to the bus stop with a couple of flimsy umbrellas. We continued along on our quest and saw the bus coming down the road so my mate waved it down, stopping it at the bottom of the street's 30 degree incline. We boarded the empty bus, and as we were searching through our wallets for the correct change to hand the middle-aged female driver, there was a loud thud and the bus lurched forward, sending my mate to the floor and me into the pole where the "next stop" button was mounted. It was clear to the driver and I that the bus had just been rear ended- at a fairly high speed. We were going to leave, but the bus driver ordered us to stay put and wait for a replacement bus, so I sat and listened to what the young driver of the R33 had to say in his condition of panic. Apparently he came over the crest and saw the bus so he put his foot on the brakes, pumped it and tried to regain control of the car, but nothing worked on the water slicked decline. I figure he must have been speeding but don't know by how much, because we weren't around when the police finally turned up (took them more than half an hour). He said he had bought the car only a month prior to this for 20k and was yet to insure it.
I couldn't say anything to the owner, there would've been nothing I could do or say to make him feel better; and I was also overcome by that feeling you get when you're involved in or witness a bad accident, so my mate and I remained silent.
When we were informed that another bus was on it's way to collect us: the only two passengers, I got off the bus and took a few pictures, incase anyone here might know the car, while we waited.
And if the owner of the car reads this, I send my condolences and I'm glad you walked away uninjured. With the conditions the way they were that afternoon, it could have ended up far worse. sad.gif
https://www.sau.com.au/forums/topic/102778-33-crashed/
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
