Hi everyone,
Looking at purchasing a '89 GT-R (R-32) that has not been complied yet.
It has HKS BOV's and a cat back exhaust as well as 18 inch wheels. These I'm presuming will all need to be changed for compliance? Seatbelts as well?
Any suggestions on who's best in Adelaide for compliance?
Good workshop to check car over. Compression test, etc as well as checking underside of car.
Any info would be greatly appreciated.
Cheers
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/
The car will pretty much have to be returned to stock form to get through Regency. Your BOV will have to come off, source some stock 16" rims, the exhaust would be fine as long as it still has the cat converter, and is below 90dB at 4000rpm.
Then all the other things have to be done, like child restraints, fuel filler changed, flat side mirrors (or less than 1.2m curvature if convex), high rear brake light, seat belts should be fine as long as they're not frayed.
Theres more things that need to be done, those were just off the top of my head as my GT-R is going through Regency next Tuesday so I've been double checking everything before then.
A few of my mates had their cars complied at Best Enterprises, I think theyre around Wingfield way, just off Cavan Rd or something.
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1887655
Thanks for that.
Do you know if the wheels have to be standard or just standard size?
I will have to probably source the exhaust as well, what have you done with yours.
I think you have a similar thread running as well.
Cheers
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1887811
The car was bought on the "15 Year" rule.
Not sure what bearing this has on compliance rules in SA.
Anyone got a direct link to the relevant SA gov. dept?
More info needed guys.
Cheers
Edited by gtrtech
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1888061
15 year compliance is cheaper than SEVS, and can be done at heaps more workshops than SEVS cars. If the GT-R was SEVS it would have to be complied interstate as far as I know as no workshops here have become a RAW for the R32 GT-R yet.
I'm not sure if you need the actual factory rims, perhaps just the same size? Someone know about this? Luckily my car came with the factory rims. I'm sure most compliance workshops would keep some stock rims lying around.
I got my exhaust swapped over to a stock one by Mark at Exhaust Technology, 253 Goodwood Rd Kings Park. 8272 7500. He's a great bloke can measure how loud your current set-up is, and if its over he can swap it over to a stock system, he keeps them specifically for us guys going through Regency. He'll hold your system til you get through and then swap it back afterwards.
Anymore questions I'll be happy to tell you what I can! B)
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1888256
Thanks again.
I'll give Mark a call. It's not that loud but I'm sure that it would still be over.
I really need someone with knowledge off GT-R's to check it out.
The car is not what you call spotless so I want to make sure it mechanically OK before I do anything anyway.
Boostworx seem to have pretty good reputation, what are they like with GT-R's?
Don't suppose you want to swap wheels for a while? :P
It's also got a non-standard front bar - problem?
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1888299
Thought these might be of some use to you. I got it from Regency, just outlines what need to be done to the car for compliance.
I'm a massive newbie on GT-Rs as well, but I know Keir Wilson at Willall Racing has the fastest non-Japanese GT-R on street radials. So maybe talk to him? But I have also heard good things about Boostworx.
I dont think aftermarket front bumper should be a problem, as long as its no lower that 10 cm off the ground at the lowest point. (I think this is the right measurement?)
Let me know when your ready to put the car through, and I should be able to lend you my wheels, no worries :P
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1888374
gday mate
what ya need to do mate is find a workshop that complies 15yo cars and they should take care of everthing for ya. i hav an 32gtr aswel but i didnt have it complied. my brother has just brought a 1990 jza70 supra and is in the same boat as you, needing compliance.
i kno of a couple workshops:
import complance centre(next to import spares) on sleaford road, winsor gardens
pvp imports, muller road, hamsted gradens
best enterprise, dry creek
there are heaps more out there mate. i guess just ring a couple and suss out some prices they will do for ya. good luck with it all!
james
Edited by Turbz_13
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1888647
Thanks for that James.
Compliance is second in line. I need to have the car looked over mechanically and structally before I purchase.
Emailed Boostworx and Willall about checking car out. Still haven't heard back as yet.
Any other workshops with GT-R knowledge worth trying?
Cheers
Geoff
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1890958
18" wheels can go through Regency under the 15 year rule as long as they don't rub/touch any part of the car (guards, strut arms etc) in any position ie at full lock in either direction and anywhere in between. My GTR went tthrough with 18" BBS rims on it.
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1899640
When did your car go through? Any rules changed since then?
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1899926
I have a spare VR4 one you can borrow (AFAIK it's the same as the GTR - anyone know any different?). If someone can confirm it will fit, PM me and I will organise getting it to you somehow.
EDIT: If you need two, you can borrow the one off my car too, but you'll have to wait until mine goes through regency, unless your regency date is before mine.
Edited by doommachine
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1920133
  • 3 weeks later...
if you need anything like standard intercooler, computer, turbos, dump pipes,back to cat let me know as they are sitting in my shed doing nothing, prefer to sell though,{ which im trying to do{make an offer{ you never know i might say yes}}} by the way make sure its the orig twin blow of valve, and possibly talk to mark at tilbrooks . he is easy to get hold of. peter is now only available through other mechanics as he has got to busy and is mainly a one man show.{cant do all the skylines in sa}
https://www.sau.com.au/forums/topic/102796-gt-r-compliance/#findComment-1963729
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
